This will be a little long. I am new to CNC world so excuse me if this is normal but I don’t understand it. I purchased a Shapoko 5 pro 4x4 and am using the carbide create pro software. I went on the cut rocket site to get a few items to start making and 9 of the 11 I down loaded would not populate after down load. So, I used 1 of my 4 30 minute training calls to help me learn what I was doing wrong. So after 2/3 of my call time The support group figured out that files were no longer supported. So not only did I lose a training call I lost a full day trying to figure these out. So where can I find some projects with tool paths Outside of Etsy to experiment with? Thank you.
See:
Yeah, for now, folks pretty much need to have v7:
https://carbide3d.com/downloads
in addition to v8.
If you’ll let us know which specific project files you had difficulty we can look into them with you here.
5b870074cf4c6_5b8701c63c6d8.c2d (3.2 MB)
5d5de6dddeffa_5d5de7b21dd40.c2d (333.8 KB)
5e793f85d247b_5e79402c0a9d0.c2d (127.2 KB)
6400eeb4c7dd6_6400ef32edf22.c2d (744 KB)
5ed034387bc48_5ed035106e67d.c2d (23.5 KB)
5fdeca59266fe_5fdfcad7076d2.c2d (135.1 KB)
There is one more. The cigar tray would not load. to much for reply
Let me know the link of the cigar tray and we’ll walk through that as well.
is:
which opens as:
in v7, but even going back to v6 is much the same, and it doesn’t seem to have toolpaths.
Attached as a v8 file:
This seems to be:
Note that many of these designs have one cutting a slot around a part.
Where possible avoid slotting and add geometry and cut as a pocket
and/or
I have had the same experience at CR. I do note however some of the older files were made with earlier version of CC. I went to CR to download some files to see the architecture of the file itself. This allowed me to understand the inner works of CC to CM so to speak. I then recreated the file in V7 myself. This gained my proficiency in all aspects of the milling operation.
Understanding earlier software versions used is the key. Most of them converted after saving. Now I’m into V8 and having to resave several of my own files I created.
I know this may seem tedious but it grows your knowledge base as well.
