(repurposing boardgap divided by 4 as the spacing for the metalwork)
In addition to the angle there will be metal strips of the same thickness and slightly lesser width to fill in where needed where the angle doubles up.
the next challenge is modeling the angle for the end pieces — it will need to be the correct length for folding into a U shape and to have suitable holes for securing.
The sheet metal work may need an additional variable, for now we set up a V to cut halfway through the angle thickness, and assume that dimension when bending:
Next up, a strip with V down the middle to bend for the front and back edges of the lid (which will get installed into rabbets which I’ll need to work out adding) — this will be an optional feature, then the edge pieces for the ends of the lid.
Next I have to resolve the curves at the bend points, and remove some extra flat strips I added and shorten the front/back strips at the bottom and adjust spacing for all that, and lastly work up some sort of hardware for the bottom corners.
Last will be working out a way to export all the parts and a cut list/B.O.M.
Then, cut a prototype to test the metal bending and how the boardgap value works out — probably for the first one I’ll cut the metal and assemble it, then tweak the board dimension values to fit inside.
Last consideration is more hardware — probably one would want to buy hinges, but it should be possible to make some sort of hasp. Probably the easiest way to do the assembly would be to drill holes and then use blind rivets — nails with round heads would probably be a better choice though.
After that we’ll have to look into the rounded variant which I hope can go together with just joinery, no straps:
I need to finish the design files — it’s supposed to be rainy here all weekend, so hoping to finish the design work today, then make a hardware store run this evening and actually cut and assemble tomorrow.
Challenges:
if doing aluminum strapping you either need a fixture which will secure the angle to cut out the bulk of the V relief cut, then rotate to make the V or U shaped groove at the bottom, or a toolpath which will make a flat cut all along that V edge while it’s mounted flat
for cutting out the lid parts — V endmills are not available in arbitrary angles, so this would need to be done as a 3D cut using a ball-nosed endmill, or you would need to have a fixture which would secure the stock at the correct angle and make it a two-sided operation — or, I’ve been wanting a shooting plane and shooting board for a long while — this might be the justification for finally getting one, though I’d need to get a board w/ a donkey’s ear or make one.
The problem of course, is working all day at a day job, and with a house full of other people whose schedules (esp. sleeping) I have to accommodate, my machine time is limited.
First though, we need to get a full set of design files. I’ll probably simplify them to use only flat metal strapping and leather around all the edges where angles are needed — that should be more manageable, but I found the metalwork fascinating as noted at:
Just about done on this, but I’ve been wondering — would anyone be interested in the idea of making the strapping out of a single sheet of material?
The cut away parts would be nice rectangles for the most part, so not too bad from a materials usage standpoint (so long as one could find suitable projects for them) — it really simplifies things, and I’d like to think it would make for a markedly strong box (and it would eliminate the voids underneath which annoy me in the modeling, but which I can’t bring myself to make half-lap joints to avoid).
1/8" is what I’m using in the design at the moment — I may try modeling a box which would be exactly the maximum size an XXL could cut and see if it’s something reasonable (then I’ll price out a sheet of alu. that size which will probably put the kibosh on this.
