Has anyone successfully taken an paper woodworking template and made a DXF/SVG? My father has one he’s like me to cutout on my SO3 XXL
Thanks
You should be able to scan it and then trace it, either automatically:
or manually:
If you have difficulties post the scan here or to support@carbide3d.com
I have scanned images to turn into SVG images. The only think you have to be mindful is the thresholds that your scanner will scan out. You want a good black line that is solid. As @WillAdams suggested you can trace the image or you can use the open source application Inkscape. In Inkscape you open the bitmap image and highlight it. Then in the path menu you select trace bitmap. You can preview the process by clicking on update. Just as with the scanner you can change the thresholds to get a good trace of your image. Then just “Save As” as an SVG. If you use a resolution of 96 DPI you SVG will likely be imported in to CC at the scale of the original. However if the svg is too small or large then draw a rectangle the size you need the part to be and then use the scale to fill your image inside the box to the size required.
That’s great advice, but my only concern is how do I scan plans that are larger than a standard size scanner bed? You would have to align everything perfectly and then somehow stitch the two or more images together. That’s the biggest part I’m trying to wrap my mind around.
For parts larger than a scanner bed you have several different options:
- take a photo
- fold or scan the drawing and make multiple scans and then stitch together in a pixel editor or vector drawing program
- use a copier to reduce it in size to fit a scanner
- use an outside service which has a sufficiently large scanner
- draw a grid on top of the design and count squares to enter it (I actually did that for a map of my wife’s hometown to get folks from out-of-town to the church — the priest kept a copy of our wedding invitation by his fax machine to send to folks thereafter)
- make a pantograph and use it to make a reduced size copy
My scanner utility has a stitch utility. As @WillAdams suggested there are ways around. Here is a screen grab of my utility. See if your scanner has a similar utility.
I will definitely check that out. Thank you
