Hello, My XXL is sitting outside in a box waiting for it’s home that I’m trying to build. I know the height of the machine is 16", and that 18-20" is desirable for cable/dust management. But is that a comfortable-enough height to work with the machine? If you need to service anything, change bits, etc. I don’t want it to be uncomfortably tight.
And then along those same line, what’s the minimum off the floor that ya’ll find is comfortable? I was thinking around 24" enclosure floor, plus whatever height is comfortable. Putting the top of the enclosure around 44" off the ground.
Mine (bench top) is about 36" off the floor, and I wish it were a little higher. Probably a matter of individual preference and height, but it’d be nice to not have to bend.
How high is your table saw?
Mine temporarily sits at about 40in off the ground (34in plus 6in torsion box). I find it a bit high for reaching behind the gantry so in my cabinet enclosure, I plan on lowering to 34 -35in. The top will be high enough to stick my head in without hitting the top if I make it with a set of front doors so around 6ft and a bit lower if I go with a cantilever top. I see advantages to both designs. You need to account for your vacuuming/dust collection setup in the height. Having built a torsion box made it possible to use the Shapeoko and find out for myself the space and placement I would prefer. I would not be able to work with the Shapeoko where I would need to bend down or get on my knees to set the stock, zero the bit, etc. All this to say, maybe you should assemble and place your Shapeoko on a temporary surface to try different setups before building a cabinet and enclosure. Winston Moy @wmoy just released a YouTube video where he builds an enclosure and learns some lessons in the process. He also made his plans available.
Thank You! perfect timing!
Do you all think if I cut a piece of plywood in 1/2 so I have two 4’x4’ squares, would be sufficient for the floor and ceiling? Assuming I put most of my framing on the outside of those squares. Or is that still too “tight”?
My idea was that if I could get the shapeoko low enough, I could still have room on top for the Glowforge. But from what you guys are saying, that would put the “roof” of the enclosure much too high.
The XXL enclosure I built for my son is 54" w x 48" d x 24 3/4"h, If I were to build it again, I would add another inch to the width.
His SO3 enclosure is 38"w x 33"dx24 3/4" h, this allows for an extended sacrificial bed to carve full 16" x 16", I would add 2" to the width of this if I were to build it again.
His XXL is sitting on a wooden workbench built for the SO3, 36" to top, the SO3 is sitting on a Kreg mobile bench 39" to top. We are both over 6’ tall, I prefer the SO3 height of the added 3". The Kreg bench will allow you to adjust the height.
His enclosures are built with a hinged top/front door of 24 3/4" tall/deep with gas springs so we have better access without hitting our heads on the door.
I would not use a sheet of 1/2 plywood by itself for the floor as IMO, there will be too much deflection from the weight of the Shapeoko and the stock. You need rigidity and flatness for the floor. As Craig said, you need several inches all the way around the Shapeoko. In your design, you also need to take into consideration if you want to use the front of the Shapeoko to cut pieces attached vertically on the front of the frame like mortise and tenon joinery. The height to the floor and position of the shapeoko in the inclosure could make this impossible. The other factor to consider is the ability to do tiling. There needs to be room to move the work piece past the front/rear of the machine without being too restricted by the enclosure.
Thanks. I was just talking about dimensions. I would still frame it out below and above to make it rigid. I’m using 3/4" birch btw. I hear you on the vertical-mounting, I hadn’t thought of doing that, but who knows.
Tiling is very important to me, as I’m going to be working on some 8ft pieces. I have the Pro model of the Glowforge for the same reason; it has pass-thru slots on the front and back. I was hoping to align the two machines directly across from each other to save space. Instead of moving my stock through the machine, which would require approx. 16ft of space, I was thinking I would clamp the stock down on the ends and move the machine along a track. Then, I would only need around 5 feet on each side, because 33" of the stock would be in the machine.
I’m going crazy over-thinking this, but I have very limited space. My kids will be with me a lot when I’m using the machine, and their lung-health is top priority, hence the enclosure. Thanks.
Keeping some space around the outside, and a bit over the top is really helpful - don’t build the box too close, or you’ll have a lot of difficulty squaring and maintaining it.
I am a bit puzzled how and enclosure will work for 8’ long material unless you have doors on front and back. I had planned to do a video showing the features of my enclosure, but have not gotten to it yet.
Your main question was height, I am happy with the 26" overall height, but could have gone lower due to the small diameter ( 2") hose- the larger diam you use, the more height is needed. Sending the hose out the back works well. And pls note , I mounted the control box OUTSIDE the enclosure. Cleaner design and work environment & easy access.
As a summary:
Th unit sits on a frame with a Torsion box top.
The TORSION box was made from 3/4" bottom and sides,
1/4" top and
1/2" internal eggcrate/half lapped cross members every 8" in both directions.
The enclosure is pictured here finished. I am very pleased with the result . The router noise is very minimal. The 63 dB Nilfisk vacuum is a lot louder than any noise emitted from the router when cutting. I found a low cost variable speed control for that which lowers the vacuum noise considerably. I used mass loaded vinyl on the interior of the box 1/16" thk to contain the sound, and 2 LED strips ( 30 K color) on the interior.
Thanks. For the back, I was just going to make a 33" wide slot with a removable cover. For the front, the removable part would be in the “lid”. Sort of like the Glowforge pass-through slot.
Does anybody think that it’s an issue if you can’t access the sides of the XXL, only from the front? Seems like too far to lean into to do anything I’m thinking. It seems the “full lid” enclosure variety is the preferred method.
Well for maintenance you need to access the sides of the gantry, there are screws, pulleys and the controller you would want to access, it would be difficult or impossible to do this from the front without enough clearance and moving the Shapeoko may affect the tramming.
I would guess that the best way to try is to put your Shapeoko on a base the same size as your proposed enclosure, put a plank on the side to act as a wall and see if there are issues accessing the screws on the side from the front. Can you connect something to the controller? I guess this is a reason why some owners have moved their control box outside their enclosure.
