Finger / dovetail joints
Yes, it can be done.
Dovetails have the problem of Carbide Create not being able to model this tool geometry in 3D:
Yes, it requires some sort of vertical fixture:
But the problem is, it make projects more complex — each box becomes at a minimum 3 setups:
  • mount parts flat on the machine and cut parts to length/width
  • mount 4 boards in fixture and cut joinery in two corners
  • rotate 4 boards and remount in fixture and cut joinery in two opposing corners
I find it far more workable to just cut the parts and the joinery in one operation:
