First attempt at letter cutouts
This is my first attempt at letter cutouts. Not sure how to avoid the blowout.
Used the 102 bit with default settings.
This is birch sanded plywood.
Appreciate any suggestions.
Also tried 2mm contour with a 112 bit and it blew out as well.
Did you add geometry and cut as a pocket?
Leave a roughing clearance?
Perhaps try a V carving first?
I have had good luck with a compression bit.
I am new to this… what do you mean add geometry?
See:
and/or
Get yourself a downcut bit, makes a world of difference. Or a compression bit as Cullen suggested if your stock is thick enough to take advantage of it.
I agree with Cadefoster84. I have had the most luck with downcut bits when I want the top surface to be as clean as possible.
Think of upcut bits as throwing the waste material up. They will clear material out of the tool path and will leave the bottom looking nice (for a pocket). But that action can pull up on your top edge like you’re seeing. Downcut buts throw waste material down into the path but leaves the top surface nicer. Sometimes you need more passes at shallower depths to allow the waste to clear.
Most of what I do is a finished top surface so I like the downcut bits for that. Good luck - plywood is plywood and sometimes doesn’t hold up well. Mostly because of how it’s made and some are better than others in terms of gaps in the material under the “show” surface.
I just completed a project where I used a downcut for the first pass in plywood and then switched to an upcut for the remainder. It left a nice surface and then was more efficient at the profiles.
Thank you everyone. I am learning lots from the comments.
Downcut bit for the WIN! Thanks again.
