Hi I have been using the nomad for over a year now. I noticed one day on inspection that small grooves had developed in the x-axis guide rail, so I sent the machine back and was sent a new one. Now about six months into using the new machine I have noticed the same grooves appearing in the x-axis rails again. Has anyone else experienced this problem?
What material are you cutting?
Are you using dust collection?
Have you been lubricating per:
Could you please send photos of the grooves in to support@carbide3d.com?
Hi Will,
Mostly cutting acrylic.
No dust collection the machine is standard with no mods.
I have been lubricating the rails with Super-Lube with PTFE about every week (~45) machine hours.
Here is a photo of one of the grooves, all are about the same size and run parallel to the direction of motion.
I meant to write X. I have the same issue in the same spot.
