How can I import stl file into Carbide Create, build 778?
I am trying to import a design from CAD tool to Carbide Create. The file is STL and I do not know how to import it. From the videos, it seems there is a tab called “model” but I could not find in my Carbide Create build 778.
Thank you very much if you can provide help on this.
You’ll need Carbide Create Pro for that feature.
As noted, you will need:
For the specifics, see:
https://carbide3d.com/hub/courses/create-pro/3d-tool-import-stl/
and also see
and
Note that only binary format STL files may be imported:
