How to map Z zero for a curved surface
I want to carve designs into curved whiskey barrel staves. Anyone know how to map the different Z heights to accommodate for the curve so that the design (text) is carved to the same depth across the curve?
Kind Regards,
Bryan
I don’t know what software you are using, but try this search string.
Wrap text onto surface
Previous discussions at:
If using CC Pro, then the design will be adapted to the 3D model.
