I am trying to make a neon sign out of this and I just need to simplify the image a little bit to make some no offeset channels. For instance just a single circle around the outside. How can i remove some of the lines and run a job just the outline of this image?
Click on a blank space, highlighted image will not be highlighted. Click on the lines you would like to delete press delete key. I did some for you, to show you. Use your file to do it the way you want.
That said, it’s a pretty simple/symmetrical thing — it would be much better to just re-draw the whole thing — let us know if you have difficulties w/ doing that.
See:
very basic tutorial on drawing with the curve tool — also see:
