SantaClause
(Adam Cunningham)
January 15, 2025, 2:53pm
1
I am a complete CNC newbie. I have been woodworking (hobby) for a long time, have built a few guitars, 3D printed anything and everything, and generally pretty handy.
And apparently really dumb.
Can carbide create be used to make irregular quadrilaterals? I don’t see where i can just change the length/width when i create a square. I can grab a node and move it, but it doesn’t tell me the length of each side. I know I can use the grid, but that is not ideal.
Should I just stick with freecad or tinkercad or can CarbideCreate do this?
For example, I just wanted to create a fender strat neck pocket. It is a tapered quadrilateral and I want to input dimensions if possible.
Thank you!
WillAdams
(William Adams (Carbide 3D))
January 15, 2025, 3:04pm
2
When I need precision like that I stack rectangles and put them on a reference layer and then use snap to Node.
If you have trouble with that, upload a drawing and we will walk through it with you.
SantaClause
(Adam Cunningham)
January 15, 2025, 3:16pm
3
Gotcha, I had already figured that method out.
Maybe i need to temper my expectations, haha.
Drag and drop from tinkercad seems like the easiest way then. Tell your devs to make this a thing
I would love to be able to click a side and it tell me the lenght so I can double check stuff before sending.
Is CarbideCreate designed to be less robust on purpose? I was really hoping to use it for everything, but I guess that is me not knowing any better.
Thank you, sir!
WillAdams
January 15, 2025, 3:23pm
4
There is a measurement tool which may help:
Alternately, the new Measurement tool in Carbide Create makes this a bit easier:
[image]
Measure from Node-to-Node:
[image]
Note the angle (11.311) and draw a line:
[image]
Select the larger circle and the line:
[image]
Rotate
[image]
[image]
Done
[image]
Group
[image]
Align Vectors
[image]
(twice)
[image]
Note that due to the different sizes of the circles things do not line up as one might expect.
Repeat this for the other circle — probably easiest to align the sm…
It seems to me to be designed on the principle of the 80/20 rule — 80% of typical users use fewer than 20% of implemented features of typical apps, and is optimized for ease of use, and application to typical projects, e.g.,
https://my.carbide3d.com/#Projects
Drop tray
Cutting board
Signs
Clocks (well, faces)
Pendant lights
That said, I’ve pretty much been able to make anything I’ve wanted to in Carbide Create:
Given a prototype base:
[image]
How to make it in Carbide Create?
First, we have a pixel image with some dimensions:
[F-86 base scan with measurements]
We import that into Carbide Create:
[image]
using “Set Background”:
[image]
and adjust for size:
[image]
[image]
It’s then a matter of drawing and toolpaths and so forth (we will try to do it w/o Create Pro, but will also show that).
For reference, there is an overhead view as well:
[DSC00036]
and see:
There’s always a ton of discussion surrounding the limitations of Create and how people “need” to move to another software. Lots of the “features” in software amount to automated thought processes. These are definitely handy in reducing the amount of attention needed.
However, you don’t “have to have” expensive software to accomplish some ambitious projects. Our latest video features an exploration with the Free Version of Create. Perhaps the video will spark some new ideas for your next b…
system
(system)
Closed
February 14, 2025, 3:23pm
5
