helipaddy
(Patrick Wills)
October 16, 2023, 9:19am
1
@WillAdams FYI I went ahead and cut this and found that the end pieces could connect ok…
…but that the side pieces definitely couldn’t. Even after a decent amount of cleaning up the tenons are almost a millimetre too wide.
I’m not sure it’s very easy to amend your original file , however I thought other readers ought to know before attempting.
Other than that it was a joy to watch the process. It would be slightly better if there were tiny tabs on the panels because the last run by the V-bit does just about pierce through.
WillAdams
(William Adams (Carbide 3D))
October 16, 2023, 10:45am
2
If you have an SO3/4/Pro have you calibrated your machine for belt stretch?
The typical technique for machine calibration:
https://my.carbide3d.com/faq/belt-stretch/
depends on precision measuring tools, and is limited by the reach of the tools in question.
EDIT:
It also depends on access to the MDI — if using Carbide Motion v6 it will be necessary to enable this in Settings | Options:
[image]
It should be possible to cut strips from a suitable blank of material, one along each axis — so we set up a square file which matches an available blank of material:
[ima…
If not, post the file?
Probably you can salvage this by using the belt stretch factor and using it to resize a copy.
helipaddy
(Patrick Wills)
October 16, 2023, 11:07am
3
I have never calibrated however I couldn’t see that working as it would make both the tenons and the mortises wider
WillAdams
October 16, 2023, 12:10pm
4
I will try making an STL from the files I posted and see what happened.
Probably you could fix this with a chisel and some patient fitting.
gdon_2003
(Guy Donham)
October 16, 2023, 8:04pm
5
I feel your pain. I was in a hurry to make a board with alternating purple heart and maple. This was to make a bowl from a board. I never moved the graphic together to see if it was symmetrical. The result was a failure. However I poured epoxy to fill the gaps so all effort was not wasted.
WillAdams
October 19, 2023, 1:44am
6
Exported the G-code from the file and used it to make an STL which was then imported into OpenSCAD:
Checking the dimensions we need:
and things must be offset by:
and adjusted by Stock Thickness:
Unfortunately, even after repairing the STL, I wasn’t able to get intersection to work with this file:
Going to go try something else…
system
(system)
Closed
November 18, 2023, 1:44am
7
