I’d be in for the “Shapeoko Upgrade of the Month” club! Where do I sign up?
This is fun. My next new thread will be Let’s talk about Linear Rails…
Then Let’s talk about 800w 110v spindles the next step up from trim routers…
And then…
IMO it’s better not to break anything. Controlling spindle torque enables that. ![]()
And didn’t you say earlier that “I’ve had my XXL for 3-4 years and still on original wheels… how are yours failing?”
Why did you “say” that?
Controlling spindle torque has its place, it won’t do much to help if an endmill is plowed into a vise or chunk of aluminium.
I have had my XXL since they were released, and have been quite lucky with it - not one big crash yet. However prior to that I had a standard SO3, which was my first CNC. The wheels on it did not last so well - it had a few decent crashes. My point is not that the wheels fail (in my experience they don’t seem to) but i think its a good thing having a weak point on a machine that is targeted at the newer end of the CNC spectrum, V wheels are cheap and easy to replace
You got me all hot and sweaty over here…
Maybe this would speed up the process.
But wouldn’t the stepper motors just slip or stall before something broke if the endmill wasn’t spinning? I guess I haven’t done that yet?!
from running a hdz into a bitsetter…
no they keep going
Cool - what all broke?
my router came out of its holder, a few acentric nuts came loose so that vwheels came off their track, and I had to retighten some belts
Sounds like HDZs can provide a lot more than the 18 lbf of the stock Z axis! You’re lucky the router wasn’t running at the time! I, and likely many others, have broken both Z and X axis V-wheels on stock Z axis Shapeokos when crashing running routers.
Has anyone out there broken V-wheels when the spindle wasn’t running?
2020-01-03 Update: This issue was discussed in depth in an earlier thread. The question wasn’t answered though.
Surprisingly, the V-wheels apparently don’t contribute significantly to Shapeoko deflection when compared to that from stock and steel drive belts!
Huh, I work for 3M and I’ve not heard this story. Interesting
Can’t find the article I read, but here’s a journal article — turn to pg. 18:
This topic was automatically closed 10 days after the last reply. New replies are no longer allowed.
