Making a plinth block using Carbide Create Pro (and other software)
…as requested on support…
I’ve attached pictures of the plinth block I’m trying to copy and the Carbide Create file. I’m not trying to get the plinth block exactly like the original, just something close and 10" tall. I was able to get the tool paths to work with your advice to use contours. There will be some needed adjustments but at least I’m closer that before I received your help.
The most expedient thing to do is to draw up the profile and model that in a tool which is able to extrude the drawn profile.
Since the images aren’t square, easiest thing to do is to import them into a tool which allows rotation, then begin re-creation:
We use the technique from:
to extrude the design:
which may then be imported
With a bit of rotation and adjustment we have:
side_profile_ms3db.stl (1.1 MB)
which imports:
Import a squared up version of the image to use as a reference:
A bit of re-drawing yields:
which may then be subtracted from the 3D model:
Thank you for the response. I’m amazed at how fast you responded after performing some complicated (to me anyway) tasks to get there. My problem is I do not have training in the programs you used, so I don’t have the skill set to get it completed as you did. I also am in the middle of a remodeling project and need to get the plinth blocks completed or decide on alternative. I’ll continue to work on the plinth blocks, but considering the software and knowledge I need to get it done, I’m not very confident. Do you have any other suggestions? Thank you.
You could have instead just re-taken the photos to make them square (I usually arrange such things on a gridded cutting board), then done the re-drawing in Carbide Create:
OpenSCAD is free, and it’s pretty obvious what the two lines of code do — presumably there are other 3D tools which could be used for this — I suppose you could buy:
and use that.
If you want me to send the file I made, let me know at support and I’ll put it on Google drive and send you the link (too large to e-mail).
It looks like I have a lot to learn. I didn’t know I could import that picture directly into Carbide Create. If you would be willing to send me the finished file that would be awesome. Hopefully, when this remodeling project is completed I can spend more time learning some of the software and using my Shapeoko more. Thank you.
Toolpaths are simply a matter of creating/defining/drawing surrounding geometry:
and assigning 3D Roughing and 3D Finishing toolpaths:
Heresy perhaps, but maybe sometimes CNC isn’t the answer? Depending on how many you need I’d cut the basic profile on a router table or shaper and then hand carve the pattern with a gouge and veiner. Less fun I guess, but done way before I’d get the programming figured out.
I’m sure I’ll try doing plenty of things the hard way while I try to learn to use my new machine, but in the midst of a renovation project on a schedule is not a relaxing learning environment if you only need a few of them.
I’ve been thinking about using the CNC for the arches and leaf pattern and using a regular router table for the rest. I need 50 plinth blocks for the remodel project so hand carving some of that would take a lot of time. It’s just hard to give up trying to figure out the programming! But, you are correct,trying to learn the programming in the midst of a project may not be the best plan.
For 50 I’d work through making it work on the CNC. Hiring someone to create the required drawing might lower your stress level and move the project along. I did that for a complicated 3d printed part I needed and it worked out well.
Since you can run all the stock you need in a few passes of long boards on the router table that’s probably a more efficient use of machine time, reserving the CNC for the carving step. .
I did the design work, step-by-step above, and provided @bjwoodworking1960 a Google drive link to the file. All that it needs is tool selection and applying 3D toolpaths (which was also shown above).
I had some success and I was able to get the main 3D profiles, but then the arches and leaf pattern don’t come out because the 3D cutouts change the depth of the workpiece. How do you get that to follow the depth of the 3d cutouts?
The arches and leaf pattern will follow the 3D cutouts when they are modeled in 3D as shown above.
OK, I will run it in the morning. It looks like it will take over and hour to run it.
Only run it if the 3D preview is as you wish. If not, work out why the 3D preview doesn’t match your expectations.
