New to CNC and software
I am looking to change my career path and think that CNC can provide me a way to enjoy what I do and be able to work into my retirement and make a little money. I know there is a learning curve and will have to learn before diving into 3D, so I am wondering if upgrading to Carbide Create Pro immediately isn’t the right thing to do. I have so many ideas for 3D already. Is there any reason to wait?
Thanks
I would suggest waiting until you have at least worked through the videos at:
https://my.carbide3d.com/
esp. “Hello World/Contour/Pocket/V carve” and the Projects:
https://my.carbide3d.com/#Projects
and
https://carbide3d.com/hub/courses/create/
For a further reference read through:
Then, once you are confident in 2D, you can request a trial for Carbide Create Pro at:
and work through the videos at:
https://carbide3d.com/hub/courses/create-pro/
As a newbie (approx 3 months under my belt…and retired) I agree with Will’s advice. Much like life, I felt it was important to crawl then walk before trying to run. As I felt comfortable at each stage of my learning curve I would self-graduate to the next stages. And at least for me, the 3D portion is more like running on a treadmill set to 12. There are a couple of features in the Pro version that I find helpful even without doing 3D, but I think it was beneficial to learn the basics in the free version to fully appreciate the extra features in the pro version. YMMV.
I too agree with Will’s advice. There’s a lot to learn in the CNC crafting world and learning the basics is key to success. 7 months in with dreams of 3d carving, I still love what I’m doing with 2d. I might never cross over to the 3d world. So many projects so little time!!!
Further note, there is also:
That said, a counterpoint for just getting Pro out-of-the-gate would be the nifty toolpath options:
  • ramping
  • Stock to Leave
  • toggle for climb vs. conventional
  • Engraving
  • Facing
in addition to the 3D stuff which I often forget to use, or work up a complicated work-around for, either because I’m doing a tutorial for someone who doesn’t have Pro, or I forget that they are there.
This is all very helpful. Am intrigued with the videos so far and realize from them so many things I had not thought about.
Thanks for the info.
The big thing is, one can pretty much do whatever one’s patience will allow one to achieve:
even w/o what would normally be done in Pro or using a traditional 3D CAD/CAM tool, though I will note, that once one runs into the limitations of Carbide Create we do sell:
for folks whose work takes them to full 3D.
If you want to make your own designs I agree with the suggestions to start simple. Everyone knows circle, square, rotate - these are everyday terms we can all visualize. But the language and approach to 3D - slice, mesh, assembly, lofting - is entirely its own. It also depends if you have other applicable creative background it might be easier to learn.
