none of my files from CC will open after upgrading carbide create how can i restore
Carbide Create v7 is available to download. V7 can open older files and then save them in v7 and CC v8 can open them. This has been documented for some time. The only exception is v7 3d projects do not import properly into v8. But regular 2d programs import fine from v7 to v8 if you open them in v7 and save them in v7 format. V8 changed the format of the files significantly and is not backward compatible with all versions just v7.
Thank you appreciate it, I went from. I believe it was V5 to V8. I have to go put V7 in and fix that. Thank you very much.
Specifically, see:
