Plunging too deep on second cutout
Have had his problem for the past few recent uses. I have two different designs made, thus different g-code, and it’s happening on both sets of corbels I’m trying to make. I programmed it to make a set of two without having to change stock and save time.
The simulation shows the tabs on the second cut-out so it isn’t a depth setting in the toolpath
I am setting all zeros before cutting, using a bit setter, not changing the bit between.
First cut out works perfect, leaves tabs perfect, really happy. Then the router retracts and moves for the second cutout and plunges 1/2 inch into the material (programmed to start at .125 inch and step down .125 each pass.
The bit (201 1/4 inch endmill) handles it fine in the pine, but the problem is the CNC losing the z-zero in the middle of the cutting, then cutting through the bottom of the material by 1/2 inch. I have to stand there, and force stop the cut through the program once I see it go through.
Any thoughts on why?
Post your C2D file. Screenshots and pictures just don’t provide enough info to be useful.
That said, what is your retract setting? Could your Z be going too high and losing steps at the top of travel?
Where possible avoid slotting and add geometry and cut as a pocket
and/or
Bingo, I haven’t cut another one yet, but I bet this is the problem! had it set to retract 1.5 over top of 1.5 material. I bet it was too much, have addressed this in the code and will confirm later.
Thank you I couldn’t figure that out, and wasn’t even thinking about that.
Kyle
That was indeed the problem, cutting like a dream now. Many thanks for the support.
Kyle
