TOT806
(Jadd Hasenauer)
August 31, 2024, 11:04am
1
i just got my machine and making something from a purchased file instead of trying to design my own. I was under the impression that all I had to do was click 3d rough and 3d finish but that is not the case can someone help me with this file
WillAdams
(William Adams (Carbide 3D))
August 31, 2024, 12:05pm
2
You have to draw and select geometry which defines where the 3D toolpaths will be cutting.
See:
https://carbide3d.com/hub/courses/create-pro/3d-tool-import-stl/
and also see
First, configure the stock:
[image]
Draw in the geometry for the bowl and place as desired:
[image]
Inset by the desired width of the rim of the bowl:
[image]
[image]
Offset to the outside of the bowl by endmill diameter plus 10%:
[image]
[image]
Draw in geometry to define the stock (since we’ll be working subtractively):
[image]
Go to the 3D model tab and model the stock:
[image]
Select the geometry for the inner curve of the bowl and model it:
[image]
[image]
Then im…
and
as requested on support…
Given an STL file:
[image]
which one wants to cut out as:
[image]
one first loads it into Carbide Create Pro:
[image]
which previews in 3D as expected:
[image]
When an STL is imported, the perimeter will be traced:
[image]
Assuming one wants to cut around the 3D object, one offsets from this by endmill diameter plus 10% or so:
[image]
[image]
It is then possible to assign a 3D roughing toolpath using this offset geometry:
[image]
[image]
Then a 3…
— note that only binary format STL files may be imported:
If presented with a set of STL files in ASCII format such as:
[image]
which will not import into Carbide Create Pro, they must be opened in a 3rd party tool such as Microsoft’s 3D Builder:
[image]
and re-saved as a binary STL which will then import as expected:
body_binary.stl (1.8 MB)
[image]
If you’re still stuck, mail the file in to support@carbide3d.com and a description of the dimensions which you want to cut it at and we’ll work up a custom tutorial at:
This category is for Tutorials relating to creating projects on your CNC machine.
