Got the Cardbide Create 3d Pro code (thanks for the help) and decided to test out an idea for a rosette. Bit more ornate than I’d have at home but still cool.
Neato.
Neato.
Would you share the files. I like it.
cool idea/effect…
what was your design approach to this?
I should double check the rights on the rosette image before posting.
But essentially I create the workpiece, add a square and circle. Use the model tab to extrude the base thickness, add the image of the rosette, fiddle with a half dozen settings then cut.
1/16" (1.5mm) tapered ball nose and 1/4" square endmill. No roughing pass, just went after it with the bit.
It’s a simple design to make — should yield to using techniques such as are described in:
but c.f.,
The image came from here : https://www.pinterest.com.mx/pin/699535754606232897/ and there are rights involved. So please observe the restrictions.
rosette_pine_test1.c2d (651.2 KB)
Copyright material is for commercial use. Fair Use Policy lets you use copyright images for noncommercial personal use.
You cannot use copyrighted material for commercial use. You are not supposed to sell products that include copyrighted material.
https://copyright.gov/fair-use/more-info.html
https://www.copyright.gov/title17/92chap1.html#107
