Any sort of content related to CNC with Carbide 3D machines is welcome here.
While not ranking, I’ve been trying to keep up with #MaterialMonday at:
Evening @Julien
Seen one typo under troubleshooting & maintenance - “Crashing the mashine”
Every Good Read needs to know a little bit about the Author - I would love to see a little section about you, why you did this, and your journey from minnow to King frog of CNC
I know you don’t want to direct link in the V2 but i think an additional reading sheet / appendix would be worth while (i too am a 20 deep serial clicker Start at F&S end up at nema stepper motor micron accuracy lol) i would like to further back this up by my recent experience as a use case to why.
I was reading the F&S section and Tool paths and had my first epiphany (thanks for that DOC vs WOC) and there was a stand out quote you said
“If you go for narrow and deep (and you should!), given the small WOC values you will definitely need to take chip thinning into account.”
i found myself thinking why should i i didnt really get it etc but like most things i just go with it by applied knowledge differences. i.e. yours better than mine.
However as i was looking for the V2 link to the document i cam across the link to " The Definitive Talk on Adaptive Clearing in HSM" this 40 min Video + your document has warped me to new thinking and already reduced some of my tried and tested jobs by 15+mins. it has also solidified my experience and knowledge with the “i knew this but it had not clicked yet” if that makes sense
So as you can see from my real example if it was not for that chance link find, i would not be better off. So i would urge you to create as suggested an appendix / essential reading / viewing page to by digested at different pace to the main document.
So that is just my two pence worth
Again an excellent document Julien, if i can help with anything please let me know and i will do my best to assist you
Cheers
Jon
Thanks for spotting the typo (and in a title…if that is not “hiding in plain sight”…)
What your example is really telling me, is that there is are parts of the e-book where I drop a bit of information (or even opinion) without explaining enough.
But you guys will really make me reconsider providing a set of links / watchlist appendix…I guess we could do a quick poll here on the forum, figure out the top10 most helpful resources, and include that along with a brief description of why they matter.
10 posts were merged into an existing topic: Speeds, Feeds, Power, and Force (SFPF) Calculator History
This excellent e-book recommends a narrow (RDOC) and deep (ADOC) and my recent attempts have found this to be a very good strategy; however, when starting a pocket the first cut is always a slot with maximum RDOC and when coupled with deep ADOC this leads to a very large cut at the start of each pocket.
I’m using Carbide Create so, ramps and adaptive cutting are not options. What should I be doing?
We touched on this briefly in this post and the few following posts.
If you want/need to stay with CC, the (only?) option we were discussing that would work for pockets to “emulate” the benefits of helical ramping for cutting at large DOC, would be to:
That way, when running that second toolpath, the endmill will plunge to full depth (into air), then it will take a few turns in the air, avoiding any slotting/full tool engagement because by the time it starts actually cutting material, it will only be using the small stepover (low RDOC at full DOC) to cut into the walls.
Now, since CC adapts the toolpath to the shape of the pocket profile, for a rectangular pocket you would need to adapt the shape of that inner pocket accordindly, in fact it would need to match the trajectory followed by the endmill during those first few moves of the endmill in the second/main toolpath.
Now that I think of it, the “offset profile” feature would be perfect to do this for any arbitrary rectangular pocket. I’m not sure I’m being clear here, and this is all theory as I have not tested this (I mostly use VCarve and Fusion by now). If you are willing to test this approach and if it works for you, I could then include this tip in the ebook. Who knows, we might even convince the CC developer(s) to automate that behavior (though that would be a very convoluted workaround to just implementing…ramping
@Julien
Very well explained!
But also this highlights why people move away from using Carbide Create once they have learnt enough about good machining toolpath strategies that simply cannot be done easily with CC.
Less experienced people stick with Carbide Create and unwittingly, prematurely and extensively wear out their end mills and have a less than stellar experience.
IMO, there is so much basic stuff that Carbide3D (@robgrz) needs to fix or put into Carbide Create Basic before they launch the “PRO” version. Indeed, without these basics it could not be a “PRO” version anyway.
Getting good toolpath strategies with workable F&S is essential for newbies, occasional users and serious hobbiests alike as well as the other functionalities that have been requested and are still not here. I know they are working hard and have made some headway with CC but there is a long way to go to convince a serious hobbiest to spend money on it. Hopefully they will be up to this serious challenge!
If they could get CC Pro to have most of the functionality of V-carve Desktop without the 24”x24” limitation (to run on the XL and XXL ) and with true 3D capability at around $300 or so then they would have a winner.
Rant over… lol
Thanks! Sounds like the best plan is to accelerate my study of Fusion 360.
Unless I’m missing something, even the latest Vcarve Pro 10 doesn’t have the desired HEM strategies that Fusion provides and @Julien’s eloquently explained work-around addresses. ![]()
Fusion 360 is free for hobbyists, but has a bit of a learning curve. @wmoy has some nice videos showing how to use it with Shapeokos - here’s one of them.
True, but it does have a variety of ramping options, so even though you don’t get adaptive clearing, you can still adopt the “narrow & deep” approach for (regular) pocketing, without resorting to the manual workaround described above.
So, to each his own, it’s doable in CC (and looking at what @WillAdams can pull off in CC, I would say pretty much anything is technically doable in CC
), it’s easier in VCarve (but $$$), and it’s easiest/built-in in Fusion360 (learning curve + evil Autodesk corporation etc…)
While VCarve Pro does not have many capabilities that Fusion has like adaptive clearing, it also has many that Fusion doesn’t. A circular saw and a jigsaw are both useful in your shop, while each will cut wood they have their place just like these software, they each have their strengths and weaknesses.
Sorry, I can’t see how that works. Could you or @luc.onthego please provide a simple example?
“evil Autodesk corporation” ?
Do you trust Autodesk to provide Fusion 360 free to hobbyists forever? To me it seems like the drug dealer who gets you hooked and then starts charging you for the drugs. F360 is very powerful and I like using it, but I am just waiting for the day it is no longer free. A similar thing happened with Onshape, and I’m glad I didn’t get too far along with it before they changed the policy.
Thanks!
I’m actually hoping to do a finger/box joint layout which will only require one setup and two tools and be almost void free — we’ll see.
Yep, exactly what I meant. Fingers crossed, I enjoy the Fusion360 drug a little too much at this point.
Even competent “evil” corporations probably try to do what they perceive is best for their bottom lines. I can see where offering Fusion for free to hobbyists could do that.
Well I am a full on junkie lol
It was a joke really, to summarize in three words the concern that some people have with cloud-based software. Me, I’ll enjoy it as long as it lasts, which may very well be for longer than my CNC addiction lasts anyway, and as you mention they may have an interest in keeping youngters/sutdents hooked for ever with the free model, as long as it brings business down the line when they are in charge at work later on.
And if they do pull the plug, I’ll learn the next popular free one, a few tens of hours of learning every 10 years in not something to worry about
I just realized that the “advanced” (e.g. helical) ramping strategies in VCarve are only available in the Pro version, and I have the Desktop version (that only has linear ramping at an angle), so no easy way to show what I meant. With linear ramping only, it may look something like this:
Initial ramping (light blue) down to full depth (in that case it would still be slotting during that ramping phase, but at arbitrarily shallow DOC if you make the ramp long enough), and then full DOC passes round and round up to reaching the outer perimeter of the pocket. I would use a slow “plunge rate” (in that case, not so much a plunge than a gradual descent), and then a much faster feedrate for the cut after the ramp is completed.
But this is all theoretical, in real life I would long have closed VCarve and fired up Fusion360 for this scenario ![]()
@julian : my trial version of Vcarve Desktop V10 has Ramps with smooth, Zig-Zag and Sprial just like the Pro version. Are you sure about what you said ? - because :
I wrote to Vectric about two weeks ago and had them confirm to me that Desktop and Pro were IDENTICAL (other than the differences in their chart on the web page). They confirmed that all the Design tools, toolpath options etc were exactly the same.
Since I only have the SO3 the 24"x24" limitation does not worry me and the rest I can happily live without as I am not a commercial user.
