While working on an end grain board, the steppers began to chatter rapidly, and then the machine unexpectedly moved up the Y axis, ruining the board. Any idea why this might have happened?
I made sure there were no obstructions.
I’m running it again to ensure it’s not a G code issue.
I have successfully made around 20 of these with no issues.
Thanks for the response. Unfortunately I don’t believe this is my issue.
I’m using a 0.5mm ball nose with a 12.4-degree taper for deep inlays, approximately 0.25 inches. I’ve never encountered any issues with it before today. When I reran the program, the problem didn’t recur. I would really like to understand what went wrong, as it ruined a commissioned project. All ideas are welcome. Also I use Vcarve Pro, carbide motion 622, so maybe just a little out of date.
The stepper motor wiring connectors are likely suspects. If you jog your machine while gently flexing/straining the connectors/wiring by hand & the axis grinds/stutters/stops, that’s your issue. The connectors are notorious for giving intermittent issues - seemingly fine for a bunch of runs & then screwing up for no apparent reason. One thing to do is to secure/tie them to prevent strain on them. If that’s not enough, you can look at getting a new wiring harness. Or you can cut off the connectors & put new ones on or even hardwire the motors - Carbide3D will obviously not support this last option but it is the most dead certain way to make a secure connection that will hold up under machine vibrations.
If it’s not the wiring connectors, then the next thing to replace would be the controller board.
