Slopes in CCPro
Probably the easiest thing to do would be to export an STL from Fusion 360, then import that into Carbide Create Pro.
That said, if you post a link to your .f3d file, I’m sure some folks here can guide you through the CAM setup.
That said, doing slopes in Carbide Create Pro requires either over-modeling the slope:
Or, one can create a greyscale height/depth map:
and there are some graphics specific to this:
