I'm trying to make a panel for my front door
I’ve looked for a grayscale 3d of a pyramid shaped like the bottom panel of the door but can’t find anything close. Every one I find is perfectly square.
Regrettably I don’t know how to create the image. But it will measure 26 7/8” x 19 7/8” as a finished product. If anyone can help out it’d be greatly appreciated.
I don’t do grayscale but I’d be more than happy to build you a 3-D model of the door panel. To do so I will need the height difference between the peak in the low point. Just let me know what file format.
Easily drawn up in a vector editor which has blends/gradients, or it should be possible to model it in Carbide 3D and then export as a PNG.
Here’s a .zip of a PNG:
26_875_19_875_gradient.zip (123.1 KB)
I sure appreciate the prompt help. You guys are awesome!
