Some Carbide Motion Help
I’m looking to speed up the production of my set of 3 spatulas. Right now I have it setup to cut the shape out using a contour path. I’d love to be able to profile (thicker where the handle meets the head and then tapers to the thinner end of each spatula head) so that I can use the CNC avoid the bandsaw and sanding. I believe I can do that with a pass with a bowl bit, but I’m not sure how to build that into the CB Motion file.
If someone has a quick tutorial that would help I’d appreciate it. I wouldn’t be mad if someone just wants to edit my file either. If that’s an option I can upload/email my current file.
Thanks for any and all help.
Does:
or
help?
If you’re still stuck, upload the file?
If need be, at least sketch out the desired profile w/ some dimensions?
