Swapped out Belts; Lost Accuracy. HALP!
Well, it’s getting better and it looks like you know what to tweak now.
I might try shimming the ends of the X beam to help it run square to the Y rails now.
The cheap feeler gauges idea is an excellent cheap way to get shim stock.
edit - It’s also worth remembering that you will never, ever get any machine perfect and knowing when it’s good enough and getting on with using it can be the smart choice :wink:
