Griff
(Well crap, my hypometric precursor device is blown…)
1
Received my Carbide 3D touchprobe yesterday, just finished installing it.
Running CM 4.0.409, version 2.3 controller. Tested probe to check ground, LED changed to red. Located my 1/4” Ballnose over the probe target as per the instructions, connected clip to cutter, touched probe to cutter to re-verify, got a red led. Initiated the probe cycle in CM, cutter slowly descended, touched probe target, led turned red, cutter continued to descend causing an error. I’ve made 3 attempts, same problem. Error 3 and error 4. If that means anything.
I’ve now triple checked the wiring, all appears correct. Do I need to “enable” probing?
Would it matter? I would think that end mill manufacturer shouldn’t matter provided that the mill conducts electricity and you select the correct size / type. My probe should arrive tomorrow, but I noticed the same thing playing with CM 4 and probing: It seems to only have presets for the Carbide end mills. I would think that any 1/4" Flat should work the same as a Carbide #201 or any 1/4" Ball should be the same as a #202. I hope we have the ability to enter custom values for type of end mill in the probe section.
Yep you do, it’s a setting in CM as part of the probing cycle.
@Griff - there is no need to use ‘official’ cutters, any tool should work as long as they match the spec i.e. diameter of the preset - but even then the Z should work
If you have the probe connected and the alligator on the bit, what does the LED do if you raise the probe upto to bit?
Griff
13
When I have the cutter positioned above the target at 1/2 “ and the clip on the cutter I pick up the probe and touch the cutter, red led. When I initiate the probe cycle the led turns red upon cutter contact but the spindle continues to descend. I think what we have here is a failure to communicate.
Make sure the cutter is not too high, while probing the Z it will only move down 12mm or so.
I lowered the cutter to 4 or so MM above the probe and started again and all went well.
The actual location was 1/4 off the corner. Kind of assumed that knowing the diameter of the bit and the offset of the probe itself that the X and Y zero would be where I would manually put it at right on the corner of the piece.
No biggie, but just something to keep in mind.
