Use tiling on oversize projects
I am doing carved signs measuring 20 x 42 so looking for support on tiling and indexing sections
I recently did my first tiling job. It came out perfect. I wrote about it and it is attached.
CarbideCreate_Tiling.pdf (1.5 MB)
See:
and
Keep in mind you can do tiling without the tiling feature. The Tiling Feature splits the job in a straight line across the tile height. Some jobs work better if you do them in 2 separate pieces so you can choose what gets cut in each tile.
You could also practice with a small piece of wood and just set your tile height to half the distance.
Then you can work on your process without wasting as much wood and time.
