WillAdams
(William Adams (Carbide 3D))
August 19, 2024, 2:14am
2
This depends on what sort of file it is.
Carbide Create imports DXF and SVG files (and of course opens its native C2D format).
Pixel images may be imported to be placed on a background layer to be re-drawn, or image traced: Carbide Create - Image Tracing
If you have a Pro license it is possible to import STL files to add them to the 3D model, or pixel images may be imported as depth/height maps. For STLs see:
https://carbide3d.com/hub/courses/create-pro/3d-tool-import-stl/
and also see
First, configure the stock:
[image]
Draw in the geometry for the bowl and place as desired:
[image]
Inset by the desired width of the rim of the bowl:
[image]
[image]
Offset to the outside of the bowl by endmill diameter plus 10%:
[image]
[image]
Draw in geometry to define the stock (since we’ll be working subtractively):
[image]
Go to the 3D model tab and model the stock:
[image]
Select the geometry for the inner curve of the bowl and model it:
[image]
[image]
Then im…
and
as requested on support…
Given an STL file:
[image]
which one wants to cut out as:
[image]
one first loads it into Carbide Create Pro:
[image]
which previews in 3D as expected:
[image]
When an STL is imported, the perimeter will be traced:
[image]
Assuming one wants to cut around the 3D object, one offsets from this by endmill diameter plus 10% or so:
[image]
[image]
It is then possible to assign a 3D roughing toolpath using this offset geometry:
[image]
[image]
Then a 3…
note that only binary format STL files may be imported:
If presented with a set of STL files in ASCII format such as:
[image]
which will not import into Carbide Create Pro, they must be opened in a 3rd party tool such as Microsoft’s 3D Builder:
[image]
and re-saved as a binary STL which will then import as expected:
body_binary.stl (1.8 MB)
[image]
