I’m toying with the idea of adding vertical work holding to my Shapeoko XXL. The first purpose of this to me would be efficiently and accurately milling recessed hand holes in the ends of cutting boards that I sell.
My machine doesn’t sit over the edge of my table, but I have enough room to mill a hole in the tabletop at least large enough for cutting boards (thickness wise), but also with a couple inches to spare. Because I don’t want a hole in my table at all times, and I don’t want to block the ability to store things under the table, I want to make my work holding solution removable and then I can drop a plug into the tabletop hole.
At some point I had seen some removable (think right angle jig) solutions that mount to the spoil-board via threaded inserts and then hang over the front to provide some clamping options. I did a quick search and can’t find them again here. Before I reinvent the wheel, does anyone have any input, pictures, ideas that they could send this way?
This isn’t a great picture, but all I have right now. There is just enough room between the front of the machine and the front metal apron of the Kreg table to clear the max forward cutting area of the Shapeoko plus about 2 inches.
