Wall Finish Quality on 1.5" thick Black Acrylic
After going down the rabbit hole of @Julien 's Acrylic Wall Finish Tips thread and messaging the man himself privately I’m no closer to achieving anything close to a mirror finish… I could deal with a little sanding and torching, but I feel like I should be able to get more resolution out of my machine.
Setup: S3 XXL, with newly installed HDZ, Wheels cleaned, Belts Tight, Using this 3" long Unicorn Cutter https://amzn.to/35AqMYE
Material: 1/2" Black Acrylite fused with Weld-on to create 1.5" stock
C3D Router: Set to 3 or 4 (tried both no appreciable change)
The Tool-path settings:
Roughing:
Finishing:
Note the result before and after finishing isn’t drastically different and this is the best result after a lot of toying around. Also, each travel seems to produce a slightly different result aka… traveling X+ vs X- I won’t even get into the curved letters (they are worse) …
I have 5 more letters to try and will do so tomorrow and I welcome any suggestions.
My leading guess is bit deflection and that if I switched to a 2 or 3 flute cutter rather then the purposeful unicorn o-flute I’d have better results.
What’s your strategy look like?
Roughing passes with multiple depths (finish only at final depth), check multiple finishing passes and run a couple low stepever cuts (0.002ish), repeat finishing passes is sometimes good too.
The full depth wall contouring really help smooth everything and look into tightening the tolerances and smoothing to deal with resolution around corners. Also not sure ide use a down-cut on stock that big.
That’s a thick piece of acrylic!
I tried a 3 flute back during the original discussion… Results were discouraging. As I said there, acrylic is an unforgiving material.
Did you consider casting letters?
Vince, I tried the 2 finishing passes and finish only at final depth method in addition to the separated roughing and finishing passes I posted above. Turning on full depth finishing did not improve the result and I found the separate Ramped finishing path at a slower feed rate removing .02 of the stock that was left worked better… are you saying that perhaps removing .002 of axial would be better?
Its 14 letters and custom font, so not worth the effort. Really i’m just complaining about about 2 hours of sanding and polishing if I really wanted a perfect mirror but I would settle for torch-able outta the machine.
Did you try a conventional finish pass? In something at soft it should be able to cut full depth without much issue. I was saying a couple full depth passes with a small radial step.
What did the edge look like before the finishing pass…was there much improvement.
Negative, the result before and after finishing aren’t drastically different.
Yes, but It did not like a full 1.5" depth removing .02" of stock to leave and 60"/min… Entire HDZ started to vibrate as it tried to go through the cut. At 24"/min it doesn’t have as much of an issue… but I did the ramp to help it out even more.
Oh yeah, 0.020 at 1.5 is quite a bit of load. Can you ramp down and still leave around +0.005 radial, then clean that up full depth in a couple passes?
I do the same thing for making really nice surface finish bores in aluminum.
Yes, I can try that tomorrow… to be clear… you want my roughing pass to leave say .02 axial AND radial… then have the first finishing ramp down and remove all but .0005 of the radial (and all of the axial?)? and then one last FDOC removing the final .005 of radial?
@Vince.Fab here is the result with .02 to leave after roughing, .005 to leave after the ramp down, and finally a FDOC finishing pass.
1
… not appreciably better or worse than before. I’ve got a bit of LED soldering to do on an “S” happy to try any other ideas for the remaining 4 letters in about 1.5hrs from now.
Here are videos of the 3 cuts.
FDOC
.005 Finishing
Roughing
I have a bunch of questions…it looks like it is several plates glued together. If it is how is it glued together? Have to tried the cut on a thinner sheet to see edge finish difference? Have to played spindle speed? I’m leaning towards more speed on finish pass. Make your cut wider to help the chips escape maybe…
There are a million variables we could play with…but if I remember correctly you said this is a one off build…time and money…I would sand and burn
No, this is the only acrylic stock I have.
I think for the next go I’m going to try a 2 flute down cut endmill and see what happens (only other bit i have with >1.5" CL)
To humor me can your vacuum blow as well as suck…or do you have an air compressor…
It can, I’ll do that next. As a note, the 2 Flute downcut was not the solution that idea just failed.
I don’t have feed or speed solutions but you can hit the edges with a torch and get a very glossy edge
I think he’s trying to reduce any work before torching.
Well that didn’t work… while blowing did get more chips out of the slot it clogged the x axis z wheels so quick it didn’t make it through 1 letter before skipping steps.
Your other idea of FASTER might have helped tho, I cranked the C3D router to max RPM and this is the result.
Feels better after that, but still not great.
Need to get going on the rest of these. 3 letters left plus a redo due to the sucking/blowing mistake. Welcome any more trials.
Not only that, but when you fuse the layers of acrylic the glue used is really bad for you. Most retailers won’t sell it any more citing cancer as a concern.
Torching it reacts with the glue differently then the acrylic. Not a huge fan of the smell and what it might be doing to me.
We if cranking the spindle up helped I would suggest slowing the feed down. I know when I watched the rough pass I didn’t like the sound it was making. I’m all about nice even tones…
What’s the workholding? Also how big is you roughing slot around the part?
