I will give this a try ASAP. Thank you, fenrus.
found a weird bug that I just fixed
(I’m cutting some landscapes right now)
if you havent; started you might want to update
added ARC support (G2/G3) to the tool so now it can also deal with Fusion360 gcode I assume
Hi fenrus,
I finally found time to test your tool for tiling a heightmap. It worked perfectly! Thank you so much! I did a test that was 17"x17", four 8.5" squares. I’m at a bit of a loss for how to create gcode for the larger item I have in mind. The problem is that my heightmap measures 48x45, larger than allowable dimension in Carbide Create. I think I’ll be able to get access to Fusion360 in the near future, and that alone may solve my problem. Are there other avenues you can suggest? I’m typically using PNG or JPG files. Thank you, again.
Please see:
for the concepts on tiling large parts via smaller cuts.
So few options I can think of, but mostly questions
How do you get to the PNG in the first place? If this is basic geo data, you can start with an STL and then bypass Carbide Create and go from STL to gcode directly (as I did in my example)
What’s the resolution of your PNG? It would likely be a small tweak to the STL-to-gcode tool to also just take a PNG as input
Will, I think the question is that the design is too large for Carbide Create to create gcode for.
Tiling can be done after you create gcode with https://fenrus75.github.io/FenrusCNCtools/stl2nc/nctile.html which takes gcode for a large design and tiles it into smaller sections
hmm there’s an option 3
I add a zoom option that lets you zoom X/Y (and probably Z) from the original gcode. That way you can design in carbide create at half dimensions, and the tool magnifies the gcode as part of splitting it. In terms of implementation, that’s the easiest of the options, couple of minutes kind of thing
Thank you, fenrus. First, I have PNG files because that is the output format I get after I take USGS info to QGIS to define my desired extent. Another C3D Community member created this QGIS/heightmap export tool some time ago. As for the resolution, my PNGs are initially always 72dpi x some large dimensions (on the order of 50"x50"). I typically convert them to a more moderate dimensions at 100-250dpi, depending on desired detail/refinement. I welcome any suggestions for alternative ways to acquire and refined data, and I’ll take a closer look at the process you followed for Mt Hood. Also, if you modify your STL to gcode tool so it handles PNGs too, that would be great. Your help is allowing a guy with tech limitations to get fewer bruises on the head. Much appreciated!
I’ll take a look
one thing to always track is that you don’t pixelate the result; if your png is too few pixels and you make it 50"x50" you’ll be able to see the individual pixels in the final result.
ok I think that the easiest thing to do is make a small tool that converts such PNG to an “STL like file”… which then can go into the other tool for turning into gcode and then for splitting.
the one thing that keeps worrying me is how much “height” is there in a pixel, there must be some amount of metadata for that somewhere… so I wonder if you could get me an example file of sorts… I could also always just make it a GUI input box I suppose.
(“STL like” since it’ll be STL enough for any of my tools, but it might not strictly comply to the STL specification)
Hi fenrus,
https://drive.google.com/file/d/1c6NIRA5cx0UyZCG47sbcVwxbEy7hhc6F/view?usp=sharing
Here is a link to a PNG that I’m working with. It is 100 dpi and 48"x62, minimally modified in Photoshop after download from QGIS. I hope this method of sending and the doc itself work for your purposes. If not, let me know, and I’ll provide alternatives. Thank you!
got it… I wonder if Photoshop removed any Z scaling info
Image Width: 6242 Image Length: 4800
Bitdepth (Bits/Sample): 16
28M pixels… not insane (but STLs have a 2M to 4M triangle limit, I’ll figure it out somehow I hope)
ok I’ve poked at the fundamentals a bit last night, and have an “interesting” issue.
Your PNG file is 16 bit grayscale, which will give awesome fine detail in the Z dimension.
But the support in javascript for PNG seems to mostly chop this back to 8 bits (I’m very new to the javacript world)… there are some kludgy ways around that which I’m investigating.
Do you know if your origin data was actually 16 bit, or is this a case where somewhere in your middle steps there was an 8->16 bit promotion but there isn’t actually 16 bit of information?
Also do you have any idea how deep you want your Z to be? 8 bit means steps of 0.1mm if your depth is 1"…
I just opened a QGIS PNG in Photoshop (couldn’t see how else to get bit depth reading). It shows as 16bit. So, assuming Photoshop doesn’t do a conversion upon opening, 16 bit is it from QGIS. I’m including that file here.
While I enormously appreciate your help, don’t let this be burdensome for you.
For what it’s worth, I found this in some USGS documentation about the seamless DEM of the US:
Distribution and Supporting File Formats
The seamless DEM shall be delivered in 32-bit floating point raster, ERDAS Imagine .img format, ArcGrid (.adf, .dat, .nit, .stk), and Gridfloat (.flt, .hdr) files (Library of Congress, 2015). The USGS may offer additional or alternative file formats for distribution in the future.
The item I sent yesterday is from that source. It’s a 1/3 arc (10 meter resolution) data set covering the entire country. The document I sent today is from another source (ALOS or SRTM via OpenTopography, both 1 arc, 30m). I can’t get a firm fix on bit depth for these, but I think they are ALOS=16 and SRTM=32. I most often use ALOS because the data tends to be cleaner, so the more recently sent file is probably from that source, and probably 16 bit from the beggining, not 8 to false 16.
My cut depth will be in the neighborhood of 1.5"
I’ll see how complicated it ends up being at 16 bit… it sure would be nicer to get that accuracy.
small update; I figured out how to get the 16 bit data. Now I can go figure out how to do the plumbing into the rest of the system, but its plumbing not rocket science from here on out I think.
Great, and, once again, thank you!
