Here’s a couple pics of the window exhaust. If ever someones looking for a business idea, people will pay a couple hundred bucks + for this kind of window setup if they have a portable AC, or need an exhaust for their indoor workshop etc.
The splitter is made is freecad and can be 3d printed. That way if I get a dedicated enclosure for the 3d printer, or if I start pulling air out of the shapeoko enclosure I could feed 2 exhausts out.
Cool!
Seems like a versatile fumes extraction system.
Well done!
If the window is glass then did you cut the exhaust hole and four holes for the mounting screws?
It’s a cast acrylic sheet, 0.187". I have a s3 xxl but the piece required too much length (I’m not setup for tiling) so I just ripped it on a table saw then cut the main exhaust hole with the CNC. smaller mounting holes were made with a hand drill to ensure no screw ups.
There’s a window behind the acrylic sheet in the pictures.The acrylic is sitting in the frame where the screen used to be.
Also I mounted some cheap chrome handles to the acrylic so it can easily be removed if I need the window open for fresh air.
Any excuse to use the CNC. Lol. Happy Friday!
A second acrylic window outside the original glass window … I like the design. :+1:t3:
You just solved my problem! Thanks! :smiley:
I don’t know what this guy is using for his vacuum chamber lid but he’s doing an amazing thing with CNC, 3D printing, polyurethane, and a laser.
OMG, that was a lot of steps. Seems like he could have just carved 6 or however many he needed in less time.
I hope he charges $500 each for those.
Creating a custom sign for our club at work. We try hard to make sure we are putting our money into the right “buckets”, so we meet once a month to discuss our “portfolios”. Design to almost done. I’m going to add a texture layer on the background, and will post the final product.
Project dump… I have too many to count, but would love feedback or questions if you have any…
I obviously didn’t make the skull, but I did the California cutout…
My good friend posted his “need” on Instagram…I knew he was talking directly to me…My response…“I got you”. There are definitely some things that I could have done better, but learning new techniques while creating things for friends is very rewarding. Let me know if you want to know the techniques used.
Original post request with his old hand-made sign:
Design:
Letters cut. I did them in reverse so that I could also create a hole for the threaded inserts on the back of each letter.
I painted the logo area and masked it before the final cut.
Close to finished before pulling off the masking
Finished:
Great work!
Question: The text on text, would the base name stand out a bit more if you had used a darker stain or lightly burn it.? Just my observation with the light and angle I see there.
Great work on all of them.
What technique did you use to engrave the bear?
The big thing I would recommend is to learn a bit more about typography.
The Addison grace sign is quite cute, but is marred by vertically stretching/horizontally compressing the type — instead, get a set of fonts which have a wide range of widths — Adrian Frutiger’s Univers was actually designed around this conceit, hence the poster, and the type specimen booklet:
Imgur
Similarly, while lining numbers are the norm, they have two problems in their usage which show in your sign:
  • they don’t align with a hyphen, since it is vertically placed so as to align with lowercase letters
  • they read as all caps (since they are the size of capitals) and assume a greater importance than they should have in most instances — three-quarter height numbers such as were used in Warren Chappell’s Trajanus would perhaps be better, or perhaps old-style figures would have worked better
I wrote a little about this sort of thing in a small booklet which is at:
https://tug.org/texshowcase/
See:
(but note that is designed to be printed on a sheet of paper, folded, cut along a slit, then the fold adjusted so as to make a small booklet)
DUDE! That is AWESOME! Nice work. I loved that you made that from an old piece of scrap pine. Way cool. Did you use any special techniques to get the board back to your zero points when you flipped it over? Was it still square at that point?
The front surface looks slightly convex. Is it?
Thank you Will. That was one of the first signs that I made a couple of years ago and was more of a practice to get the technique of different layers down and using the paint masking technique as well. I didn’t really pay too much attention to the fonts as much as I did the layers a toolpaths. But I do appreciate the insite into fonts. I never looked at it that way and as I get into more detailed signs will certainly give your book a read. Thanks so much for including it.
Thanks Davey. I setup a jig on my machine so that I could remove and replace in the same spot without having to re-zero each time. I don’t think it’s convex, but it might be slightly… good eye.
I just used a standard 60deg. vcarve bit. I had to do quite a bit to the art work and toolpaths to make sure the pattern came out correctly. If I was smarter, I could have used shading and 3D toolpaths to get an even better look, but the customer was really happy the way it turned out.
My local lumber mill needed a new sign to replace their old plastic one falling apart. I hope they like it! This is the first piece I’ve ever painted for someone, and first time I ever painted something so nice!
