oohhuu, that stings just a little bit! ![]()
Ha. Yes. 3 times over (so far). Iâm a young-ish granddad. ![]()
Oh my goodness! Thatâs beautiful! Are you sure?
EDIT: removed name and address out of privacy concerns (please communicate such via PM)
Youâll have a blank check for 3d design!!!
You have provided hope for us all that the 4th axis is not just a pipe dream! Well done.
When do you go into productionâŚâŚ.
This is indexed moves, not simultaneous 4th axis.
I used 45 degree increments.
6 tools - 1 roughing bit (Pocket) and 5 decreasing dia ball end mills (Scallop).
You see a momentary switch behind the part.
I used a Drill tooth path with the Speed set to 1 rpm to push the button down.
The Tool path contained optional stops M0 and I left them there for the first three tools then hand hacked out the M0 for the last three tools and let it rip.
It took 52 setups. I have a pretty good based model to work with now, so I should be able to swap models, adjust bottom heights. I think âŚ
I looked into CAM appsâ the do true simultaneous path generation.
EXPENSIVE !!! Way outside this money losing operation.
Height is an issue, hence the removed trays and the rotary table hanging off the front.
I do have the height extenders.
Check your PMâs . I thought I had sent it successfully.
Oh my goodness, that is ingenious/devious [I need a new word here], Jim. Thank you for putting that concept into my brain. ![]()
Hopefully you were able to complete the rotations per bit rather than change the bit at each index location.
I did run the same bit across all rotations.
More work on the model/cam side, but better at runtime.
The person who gave me the rotary table had it setup like that.
Not my idea, but a good one.
First non-fail with a 3D carve. Itâs a gift for my wife that will become a music stand on our piano. Haystack Rock in Oregon, where she lived and I proposed.
And lot more to come
I was wondering which rock it was. Was it the third rock from the sun?
+1
Your first non-fail was that she agreed to marry you!
Youâd think.
I knew Iâd say something stupid no matter what so I planned to go for a romantic walk on Cannon Beach at sunset. Not even I could screw that up.
She and her brother insisted he was coming. Oregon was Oregon. The three of us went for a romantic walk at dusk in the rain.
the coupling for the z axis was loose. Giving it a .020 - .030 slop if you pulled up and down on the spindle. No longer a problem after correcting issue with the help of tech support .
Current project:
(mental note, cut REST machining operation after cutting with the larger tool if the latter is cutting cross-grain)
Would love to know what your setup is for flattening⌠Spindle, feeds/speeds, bit youâre using, and tool-pathing techniques. All I seem to get is burn, and my spindle seems to bog down, even with a .035 cut depth.
