I made a box for my Wixley Digital Protractor. I have had this for a long time in its plastic package and been using it a lot lately. So I made a case for it.
I used Watco Teak Oil dark walnut to finish it.
Girlfriend asked for a sign to give to her hair stylist. I didn’t ask for context
MDF and much more time finishing than cutting
Only her hair dresser knows for sure.
Cutting board 18 x 12-1/2 x 1-1/2 Maple with 2 strips of purple heart
then inlayed padauk/black walnut for the logo.
Paint job looks amazing
.Oramask???
Nope.
V-carve text, chamfer w/ V-bit, groove with ball nose and cut free with 1/4".
3 coats shellac with sanding between.
Spray with Krylon. Sand. Krylon again.
Get out the brushes and acrylic and fill in the text. Use a damp rag and patience to clean off painted surfaces. Takes two coats light color acrylic to cover dark spray paint. Possibly could have done a 3rd.
And finally shoot a couple coats of lacquer.
Looks great. How are you going to finish it?
I experienced that padouk loses some of it’s red color and turns more red-brown when finished with linseed oil.
Waiting for glue to dry on another project, decided to experiment with the 2 sided machining features of Vcarve Pro. Found Marc Lindsay’s (spelling?) video so whipped up this for some aging hippie friends
MDF, shellac, Krylon, acrylic & lacquer.
VCarve’s machining features take some getting used to vs. Fusion360 which I’m more accustom to using. Lid has a slight dish, about 1.5mm, enough to feel rather than really see. Vcarve text projected to model surface us a nice feature.
Mason jar engraved tops
I love this idea! Nice job.
Me? I am doing some prototyping
for installing a B̶i̶t̶s̶e̶t̶t̶e̶r̶ Cutter Setter (Ahhh) on a raised (1.56") Metal Cutting Shapeoko 3. After some testing, Rev B will be 3/4" lower.
Just because it looked good on paper, doesn’t mean it’ll actually work
I used walrus oil on it, I think padauk has a tendency to do that but it’s not a big deal for the logo.
Made a part for a prototype at work. Noodling ideas for an automatic cable lashing machine.
This is part of the upper guide that the little shuttles move around.
It is a student designed project, my group is providing support. They have a limited budget so we are prototyping the first revision with MDF (soaked in shellac). All the gears are 3d printed.
Anyway, they have something to test now.
Umm
very nice but its a Wixey Protractor not Wixley.
Always wanted one of those to go with my Wixey Digital Angle Gauge. They would go well in a box together
now I have to buy the protractor first
Practise is good :smirk:
I had a rusted old hatchet head lying around so I modeled a lofted handle in F360. Thought I had double sided machining licked but it turns out there was a 1mm shift when i did the other side. A TON of sanding, charring and oiling later I have new handle on an axe head that’s older than I am!
(actually, as wrote this i figured out why my setups shifted when i flipped :roll_eyes:)
Read once cut twice?
Very nicely done, is it ash?
Yes sir. The handle is stout! Honestly I don’t know if I could break this thing if I tried.
Humbled by all the beautiful work you all have shared. Just grinding wood into dust to see what comes out of the pile.
My wife picked up a small pup table to put on the back porch recently. The table didn’t sit quite level so I made a trip to the local big box lumber store for some adjustable feet, I came back empty handed. Deciding I could come up with something quickly I modeled up some round feet in CCPro and added a hex shaped pocket for a bolt head to seat in. WallyWorld had the HDPE in the form of a cutting board and a few minutes on the S3 yielded the feet I needed.
Nice work. I wouldn’t know how to properly fix the head to the handle, do you have suggestions?
And what is actually the “correct” grain orientation for tool handles? I read that for baseball bats, you would hit the ball with the radial face. Is it also true for tool handles?
