Okay so what you are saying is that despite the smaller tool and my lack of understanding, the preview will hold true?
I see the tool is tapered, I am just not really seeing how it works (yet) and dont want to damage the machine. Because as you see its not an inlay but a cut through.
Do you need the taper angle for a working gear? Are you planning on cutting two of each gear, and fastening the pairs together so that the resultant gear will have a V shape, mating with the other (which would have opposing surfaces glued together so as to create the opposite V shape)?
Basically im concerned that because the cutting part is so tiny, when it goes deeper the thickness of the shaft will hit the stock. Seeing the preview pictures and this tool am i in the clear here?
Enter the cutting length: Cutting Length: .0625" and never use it on material which is thicker than that, or on a given layer which is thicker than that. If cutting thicker material, leave steps, none of which is thicker than 0.0625" and ensure that each edge is sufficiently distant from the next up to clear the taper angle (which it looks as if you’ll have to measure).
MeshCAM may have some facility for this, but I doubt Carbide Create does.
Okay, what exactly is cutting length? I am using Carbide Create because it was much more simple than Meshcam. And Steps make steps leading up to the part or something of that nature?
Draw up the geometry of the endmill as viewed from the side, then draw a side view of the cuts which you wish to make — this should show the relief cut steps which you will need. Another alternative would be to do this as a two-sided flip-cut.
