87vetter
(Wayne Bussert)
1
Does Carbide Create Pro have a work size limitation?
Can Carbide Create Pro have the tile function?
Thanks
WillAdams
(William Adams (Carbide 3D))
2
There’s an upper limit on stock size — but I doubt anyone has a machine which would be limited by that.
No tile function yet for Carbide Create, free or Pro — have to do it manually:
87vetter
(Wayne Bussert)
3
The main question I was trying to get to is does Carbide Create allow / support a cutting area of 48" x 32"?
Tod1d
(Tod (with 1 'd'))
4
Width & Height: 200", Thickness: 20"
Pretty big. But I’m currently working on a postprocessor for a bigger machine 236" x 118" x 59" (6000mm x 3000mm x 1500mm)
Bozo
(Bozo T Clown)
5
I actively use CC 729, CM 566? for ~ 57" x 32" cutting area, no problem.
system
(system)
Closed
6
