For what it’s worth, here’s where I am at.
I wired a dedicated 20A circuit into my panel today.
I also revamped my grounding wiring on the Shapeoko. I connected individual wires from the left rail, right rail, side of the gantry, back of the Z mount, dust hose (center wire), and router base on the Z mount. Brought all of these back to a bus bar. The bus bar has a 14 ga solid wire that connects to the second outlet on the dedicated circuit with an earth connection outlet (3 prong plug-in, hot and common are plastic, ground has a banana plug).
On the CNC cabinet I have to following connected to switched outlets, that are all plugged into the dedicated 20A.
- Lights
- CNC (Shapeoko)
- Router
- CPU (connects to a power strip that powers the CPU, powered USB hub and a Ring camera in the cabinet).
I ran my first test on a 16 minute cut, with no dust collection. No problems.
I ran my second test on the same 16 minute cut, but I added dust collection to the mix. I normally run a Bosch dust collector through a cyclone setup for my collection, but I really wanted to test it.
I have a really old Ridgid, 4.5 HP shop vac that generates enough static electricity to send Marty back to 1985. Plugged that in for the full 16 minutes without incident.
All of this was with the garage door opened, after a little snow/rain mix. Humidity was reading pretty high (over 80%).
I closed everything and ran my heater, ceiling fan and air filtration to really dry it out and heat it up. Ran several more 16 min jobs without incident.
I did run one aggressive job to put it to the test. Put my “Beast” bit in and went 0.375" Depth per pass at 100 in/min., with the time machine shop vac going, into solid maple. This caused a problem and a disconnect error. It was struggling pretty hard so I am not surprised.
That said, I am running back at about 35% humidity without incident now. I have my doubts but seems ok so far.
