Is it possible to combine 2 separate files into 1? I created 2 separate Create files and want only one.
Combining 2 c2d files?
I’m afraid not officially.
There was an app for converting from .c2d to SVG posted to the unofficial Shapeoko Facebook group recently — didn’t do curve objects though — you could use that to make an SVG, then import it.
The other thing to consider would be using a text editor to merge the two files — the .c2d fileformat seems pretty straight-forward, I’ve hand-edited it a couple of times when doing support and it’s worked.
If you wish, mail the two files in to support@carbide3d.com and we’ll try to get them stitched together.
After sleeping on it, I remembered that I had used f-engrave to create the curved lettering I am using. So I can just re import it. To bad I just used a placeholder name for the export. And had over written it. That’s how I learn, do over until I get it down pat.
