I have two images that I would like to clean up. They are hand sketches of my son’s race car. There are extemporaneous lines the person put in that I would like to remove. When I go into node edit, there are hours of work to get the lines even.
I use Inkscape as a novice, not sure what to do or how to do it.
In CC I can clean up a bunch of the extra garbage, some of the lines I am unable to remove correctly using node edit.
Can anyone point me in the right direction? Don’t even know how to highlight areas I need help with.
Those traces look awful. I would be tempted to just set my image as background & draw over it.
Or fix what you can, and draw in the rest rather than trying to edit the existing vectors.
Can you post one of the images? I’m curious if that’s the best trace you can get.
I can’t get any better vectors using Trace in CC. Perhaps Inkscape offers better tools?? But with the quality/nature of the images, I tend to think drawing it yourself may be the best solution.
There may be a way to apply filters, brightness, contrast, etc… to the image before tracing that could improve the result?? I’m an amateur Gimp user, and couldn’t come up with anything.
