Bit Zero with 60 Deg Vee bit
Using a V tool for the zero at Center works well when setting the zero visually as shown at:
It’s not a good idea when setting the origin for X and/or Y with a BitZero due to tool rotation changing the results (which is why using a probing pin is recommended).
