Hi all,
I am a newbie on the CNC journey.
I have a shapeoko 5 pro with a 80mm spindle & ER20 collets.
Do I need exact collet sizes to match different shaft diameter of bits?
example: I have a few 8mm, 10mm and 12mm shaft end mills. DO I need to match the collet sizes exactly or is there a range -
can 6mm go into a 1/4" collete
Can 12 mm fit 1/2 inch
Can 10mm fit into the 1/2" collete -
I saw a post that said that the ER20 collets have a range of shaft diameter they can take. True?
When I was looking for collets I wound up buying from Maritool, mostly because they have a straight-forward website which seemed to explain things well (except for not being explicit that one would want to at least consider getting a separate nut for each collet so as to not need to swap a single back and forth). (I would also recommend getting their nifty wrench — a further organization hack I considered, but bailed on due to budget was different types of nuts for metric/Imperial)
Another notable source is:
which company rep @TDA has been very helpful here and made some excellent and informative posts.
Usual preface, I’m with PreciseBits so while I try to only post general information take everything I say with the understanding that I have a bias.
Yes and no. Assuming that the collets are made to the correct spec, ER8 / ER11 can compress 0.5mm smaller than nominal and from ER16 up can compress to 1mm smaller than nominal. By spec you should NEVER go larger. Again, this depends on a good bore, taper grind, correct kerf size, and counter bore in the collets. Even within this range, any runout, clamping force, or slip resistance is only spec’ed for nominal bore size.
I’m somewhat less bias here as at least currently we don’t really offer metric collets. It depends on what you are doing with them. One of the important specs for collets is runout (how much it shift the tool off the center axis of the spindle). If you are dealing with small cutters, chiploads, or cutting metal this can matter a lot more. The manufacturers that I know of that spec that actual collet YOU get and not just an average or AQL are us (PreciseBits), Rego-Fix (inventors or ER collets and the R in ER), Pioneer, Haimer, and Technik’s UP grade. There are different grades from most of those using differing measurement setups/standards.
If you want some more info here’s some other threads I’ve posted to related to collets and collet nuts that might be useful.
And the one that goes off the rails about torque.
Hope that’s useful. Let me know if there’s something I can help with.
Collets are cheap. It seems a false economy to not use one that’s at least nominally the right fit.
Changing collets OTOH is a pain. For my regular routers I long ago decided to buy only half inch shaft bits whenever I could so I almost never have to change the collet. (plus having had the experience of bending the shaft on a quarter inch shaft router bit in mid cut I’m not anxious to repeat the adventure) Haven’t yet figured out whether this is really an option for CNC bits.
An ER collet system will have the nut draw out the collet since it’s attached — the only inconvenience in changing is that one needs to be put away and the other gotten.
For some reason my collet nut doesn’t thread smoothly onto my spindle. It always takes a half dozen attempts to get it not to try to cross thread. Not having to unscrew it all the way eliminates that issue.
Yes, finding the other collet can also be an issue
It more that I want to be upfront about it and let people make their own decisions with as much information as possible.
Thank you though, I truly do appreciate it.
I agree in general. But, cheap is relative and dependent on what type you are going after. micRun from Rego are over $80, UPP from Pioneer are all over $110. Although to your point, I don’t think anyone would be running those worried about non-nominal.
Some routers have absolutely horrible lead in threads. Might be what you are dealing with there.
More of an issue to run 1/2" tooling on a CNC without a BEEFY CNC. Otherwise you are dumping money on tooling you can’t really make use of (cubic material removed per flute/rev issue). Getting 1/2" shank, smaller diameter tooling is also pretty expensive as most use solid carbide. That’s a lot for the blank and the diamond wheels/machine time to grind it down to a smaller diameter.
If you are having this issue on a spindle too I’d check the threads on the nut and spindle. They are usually pretty good. Might have a bad nut or need to touch up the spindle threads.
It’s best practice to at least pull out the collet and blow everything out at a minimum. Router or spindle. Debris and lacquer can cause runout that will put more stress on the machine and tooling while giving you a worse finish. It can effect it a lot more than most think it would.
