Hello Tod, got it to go! will attach a picture later.
Any idea why this will not produce an even v carve?
wolves chopping board.c2d (624 KB)
Because the lines aren’t evenly spaced. It even has self-intersecting vectors.
Pretty dreadful .svg, needs a lot of cleanup.
Thankyou Tod, would you recommend a good program i could use to convert an image into a decent vector to v groove?
This is the original image
If you’re trying to do a single V-carve, imagine the image as black & white. Which parts do you want black (carved) & which parts white (not carved)?
Unless you want to do multiple colors, like an epoxy inlay. Then you need to separate the colors and cut & pour each color separately. I’m seeing red, dark red, orange, yellow, white & black. And possibly several shades of gray on the helmet.
There’s no “Easy” button for this one. ![]()
Just a black outline really, no colours or pockets cut out, just as the image but traced lines.
A fairly easy approach for this is:
- print the colour image
- put a sheet of tracing paper/transparency over it
- trace the outline of what you want V carved using a Sharpie
Or, do the digital version of that:
- import the pixel image
- re-draw
See:
and
or
or for Makita RT0701/0700 collet wrenches see:
Here’s a ten minute attempt.
The image is small ( number of pixels ) so it doesn’t handle very well.
I used Paint.Net to make it grey scale, then Inkscape to Trace the image.
In Inkscape I remove the “fill”, add a stroke color and set the stroke width to 0.1 mm
