Dan5450
(Dan Allen)
February 24, 2025, 7:12pm
1
Does anyone have information on the best place to get guitar building files that are clean and compatible with Shapeoko
WillAdams
(William Adams (Carbide 3D))
February 24, 2025, 7:46pm
2
This has been discussed a bit here:
https://community.carbide3d.com/search?q=guitar
and in particular, some specifics were walked through at:
as requested on support…
Given a guitar body design as an STL:
[image]
and a DXF:
[image]
We import each:
[image]
[image]
and look into how the imported geometry and 3D model work out for making toolpaths.
and
Given a file in Carbide Create which describes a guitar bridge:
[image]
there are a couple of different ways which this part could be made:
draw up contour geometry and assign toolpaths to appropriate depths (note that this does not require Carbide Create Pro): Spoon Possible without CC Pro?
model the design in a traditional CAD tool, export it as an STL and then import that STL into Carbide Create Pro and then cut that 3D model using Carbide Create Pro: Instru…
and I’ve posted the links/resources from the wiki in at least one of the posts in the above search (I think — if not, let me know and I’ll dig them out).
system
(system)
Closed
March 26, 2025, 7:13pm
3
