Making a curved foot
I am trying to design a simple step foot for a cutting board out of walnut.
I just use 2 circles offset with the inside a blind cut and the outside going all the way through.
Is there a way to put a small curve on the outside cut starting at the step?
I attached the cc file that gives me just straight cuts.
Thanks for any help if this is possible.
Cutting Board Feet.c2d (11.6 KB)
I’m having a bit of a hard time visualizing the final form that you would like. Could you draw a rough cross-section of what you’d like to end up with?
Not directly in the free version, for a work-around see:
Or, use a suitable rounding tool:
If you have Pro, then you could model this using the tools in it:
Are you talking about something like this?
I forget about using a round over bit, I’ll have to take a look at what I have.
Here is a picture of what I made and a sketch of what I wanted. The wife was still happy with the straight cuts but being a perfectionist I wanted round. :smile:
Feet for cutting board
A roundover & a ball mill would do it.
You could also develop it yourself for just a ball mill. Draw in the ball mill on the section view, then transfer the tip of tool down to the plan view & draw in your circles. Measure the tip of each tool for depth of cut.
That would work nicely, it’s the simple things that I try to make difficult :sunny:
It’s a small enough curve that the 1/4" ball EM will work great.
Thank you to everyone for helping.
Pete
