Strange result in Simulations of modeled components
Modeling is, again, frustrating me.
I’m trying to create a strip of wood that will take a texture that I have an STL for.
The STL is 24"x24" and the strip is 12.75"x3". The texture looks best if I import it at about .5 size.
I modeled an ADD FLAT for the strip.
Then I wanted to remove the texture:
Since the STL is a square and my piece is a rectangle, I had to create a square piece of geometry to import the STL and make it cover the entire strip:
View 3D - all looks great…
Now I want to create the toolpaths for it:
OK…Select just the strip (the bounding geometry) and add a rouging and finish toolpath:
And…show simulation:
Why is the large rectangle showing up? I didn’t select the large rectangle when bounding the toolpaths…so why are they included?
Wouldn’t that be the size of your stock?
Upload your .c2d file?
I usually offset around a 3D part by endmill diameter plus 10%, see:
