Carbide CNC question for 3d objects
Hello,
I’m about to pull the trigger on a new Shapeoko CNC, yay! However I have a question about it’s software - probly the pro version.
I saw this youtube video where they use V-carve to create a bowl and some spoons. First the carve out the top half of the spoon, the machine stops, they flip the block over and get it as close to their original grid position to keep both halves aligned, then start the 2nd half of the spoon, which is the bottom.
I’m wondering if Create Pro is capable of such things, and also what would help to keep that block perfectly centered when you flip so you have minimal sanding after its cut out. Would the bitzero help with this, or setting my block in some sort of jig to on the cutting area to keep it in place after flipping.
Just in general how does Carbide Create handle 3d files compared to V-Carve or Fusion 360?
Anyways thanks for any help or clarity on the issue.
Spencer
Carbide Create can do two-sided cuts, but one has to create/visualize each side separately (I usually do this in a file twice as large as need be using Center-Left as the origin, top-half of the file is one side, bottom-half is the other). There is no check on an object cutting all the way through, nor on how thick the walls are.
We have a video on this at:
Basically, two-sided work is handled similarly to Vectric Vcarve (which is also a 2.5D program with some 3D capabilities) but different from Fusion 360 (which is a full-fledged 3D CAD/CAM solution).
For making spoons, it’s not strictly necessary to use Carbide Create Pro:
or see:
(which probably pushes doing 3D w/o a 3D program farther than most folks find comfortable)
You may want to look at/consider Alibre Atom3D which in its Workshop version bundles the 3D CAM tool MeshCAM:
Thanks for sending all these examples. It gives me a lot to try out and see what method will work best for what I want to do once I get setup. Appreciate the help! I’m sure I’ll have more questions once I get setup, but at least I’ll have something to show :+1:
Naturally, if you have a 3D file and can export to an STL this is much easier:
https://carbide3d.com/hub/courses/create-pro/3d-tool-import-stl/
and also see
and
note that only binary format STL files may be imported:
Yea Ill be exporting out of Zbrush and Plasticity so I have several options. Thank you again for all your help!
