A nylon brush, or a metal brush softer than the metal of the coin is a good idea as well, and probably a more traditional thing.
@RichM I am working on my own challenge coins (Navy Guy here) wanting to try some metal and MC etcher so following along. Currently i have been making some out of 1" teak, with good results.
I am trying more complex 3D designs as I go using #121 1/32 ball nose just to see how detailed I can get. Also thought about looking into making my own molds to try and epoxy pour or something. The wood works but not very heavy and durability factor is still being tested.
@TonyMurray That looks really nice, retired ETC here. Haven’t done any Chief stuff yet but looking forward to doing some soon.
@pcperks hey brother I am trying to get there few more years left. That is mainly what i have been doing is CPO/Navy stuff! Lots of good stls on Etsy and stuff us where I started now working my own designs.
We discussed creating designs from publicly available sources at:
and of course one can use Image Tracing:
and we’ve done a couple of Navy designs here already:
USN Masterdiver:
Nice detail in the chain for such a small piece!
I ended up using a blank 3x5 notecard, kind of like sandpaper under my thumb, just to see if I could knockdown the tiny burrs I could feel on some of the edges and that actually worked pretty well. May not be the best solution, but it did what I wanted to accomplish in the moment.
Nicer papers will have tiny clay particles embedded in them to assist with ink bleeding.
Would 4000 grit sandpaper be too aggressive for what you need done with the burrs? If surface finish is a major concern, a really high grit sandpaper can be used, and if you are working on metal, tile, ceramics, etc, then wet sanding may be ideal for your burr issues.
The thing is, sandpaper should only be applied to a surface which has defects or a layer which one wishes to remove similar in size to the grain of the sandpaper.
If you apply a piece of sandpaper to a piece which has such defects you end up with a smooth/rounded bump where each defect was.
If need be, use a fine flat file to take things down to a flat surface, but you’ll still have burrs inside each area along the perimeter of where the cuts were made.
Correct on the flat file. Burrs are any machinist’s worst enemy. I havent tried any etching yet, but have two of the etchers and am about to start practicing on some tiles to see how well I can work with them. Found a place that has around 50 tiles for $10. Thinking that this many tiles at that price isnt bad and it gives me some material to practice on.
I am genuinely just as concerned about the burrs within etching because I have a coin type design that I would like to create, and have already started designing it, but not being familiar with Mc Etchy tools, I dont know what to expect in finish. Practice runs are a must to see and adjust.
You might have luck just by reducing the pressure /DOC on the Etcher. It really depends on the look you are trying to achieve. By not going too deep, I can let the Etcher zoom and get very smooth engravings. The Etchers are definitely my favorite. No router noise, no vacuum noise, very forgiving for rookies yet still make cool things fast.
That’s something I will try next - I just went with the default depth/pressure, but I will reduce that and see how it comes out.
Yeah, I agree etching is a pleasant relief from the usual noises, mask etc. when cutting.
Engraved 24 stainless discs on both sides with a 90 degree MCEtcher. DOC was 0.07 inch determined by trial and error. My DOC will not equate to yours due to the nature of the Etcher (adjustable spring which I tweak as the diamond gets dull). Feed rate 200, plunge 60. I ran 200% override. No smoothing necessary. I pocketed in the wood 0.05 inch deep to hold each disc and covered the bottom of each disc with double sided tape before pressing into place. This sometimes holds the discs adequately, sometimes not, but in this example I did not lose any of the 24. But I did get to clean tape residue from the discs (yippee!). This is my home business where I buy cheap stuff, spend countless hours embellishing it, and then give it away for free. The demand is crazy. Business is booming.
Is your Shapeoko banished to the attic?
Yes, the attic of a shed where it can be inconveniently accessed by a steep stair case. I’m trying to win the “biggest Shapeoko in the smallest space” challenge.
Hope whom ever banished you to that spot is below living with the dust filtering down.
I actually really dig the CNC stuffed in the shed attic setup.
The business plan feels familiar as well but at least it’s a good time.
