This post contains historical posts associated with the Speeds, Feeds, Power, and Force (SFPF) Calculator that were moved from other threads to help tidy them up.
One of the Shapeoko competitors has a web and mobile app for calculating F&S. It has dropdowns for material, number of flutes, a slider for rpm, etc. But it doesnât differentiate between slotting, pocketing and adaptive, which would be a nice feature. It is tailored to the capabilities of their machines.
Something similar for the Carbide3D machines would be nice.
As shown in the attached file your most âaggressiveâ cut in that video was your âaggressiveâ contour cut. As shown below, that cut likely required less than 1.51 lbf and 40.2 Watts. Tripling the feed rate (and MRR) to maintain the 0.002 inch chip-load would require less than 4.53 lbf and 120.6 Watts. If thatâs too much force for Shapeoko (is it?), you could reduce the force to less than 18/30 X 4.53 = 2.72 lbf by increasing the router speed to 30,000 RPM. You could then reduce it to 1.36 lbf by reducing the chip-load to the 0.001 inch you achieved in your adaptive cut. Iâd be surprised if you couldnât use the 0.00013 inch chip-load that you used with the Nomad cutting tool steel to reduce the force by another order of magnitude!
2019-09-09 Moyâs YouTube Aluminum and Steel Speeds and Feeds Workbook.zip (232.7 KB)
Itâs also extra heat at that higher SFM. Iâm not looking to set any land speed records with the material monday recipes. Theyâre supposed to be âsafeâ starting points for people, Iâve tried to make that clear by reminding people in the videos every couple episodes.
Furthermore, I would absolutely NOT want to use a 0.00013" chip load in aluminum. That worked in steel because the SFM was so low using small diameter tooling.
Also, that video did not take into account chip thinning. Have you seen the HEM video I put out? https://www.youtube.com/watch?v=wnv6Z72Ql24
It occurs to me that another variable we need to bake into the cake, is noise level.
30k-RPM in aluminum is going to be a noisy proposition. Iâd often rather something run longer at lower SPL, for example when my wife is sleeping.
If anyone is designing an app or writing some javascript to provide feeds and speeds, it would be nice if one could reduce RPM to achiever lower SPL.
The recipes certainly are plenty safe, but IMO youâre really only demonstrating/using a small fraction of even the âstockâ machinesâ capabilities!
Iâve cut a lot of 6061-T6 aluminum on my 3450 RPM miter saw with a 12 inch 120 tooth blade. Even with a likely unrealistically high feed rate of 50 IPM, thatâs a chip-load of 50/3450/120 = 0.00012" at 3450 X 1 X Pi = 10838 SFM (HSM?).
At less than 1.05 lbf and 27.9 Watts, both of your HEM examples are plenty safe too. The 3 flute example did not require any extra force or power because the MRR remained the same as that for the 1 flute. Werenât you using a (â1.25 HPâ) Makita 0701 router?
OOPs - my bad! all of the Aluminum calculations used a K-factor of 18, it should have been 3.34. âHardest thing in the world is not screwing up!â Iâll edit those posts accordingly.
1719 PST Update: Iâve corrected the posts. At least there are now some more measurable power levels and the workbook now includes Winstonâs HEM stuff!
The 3-flute HEM example was actually run at 3x the feedrate to maintain chipload. It sounded pretty sketchy, and far more taxing on the spindle.
Miter saws are pretty different, the percentage of time the blade spends outside the cut means you get plenty of time for small chips to evacuate and for the blade teeth to cool down.
Do you have a Shapeoko? Because I think it would be far easier to put theories to the test instead of just hypothesizing.
I personally donât plan to push much more aggressive in aluminum than what I showed in the HEM test, even with mist coolant. Even here Iâm developing a subtle but visible low frequency vibration in the entire carriage during certain directions of cut. There are plenty of system dynamics âthe numbersâ donât capture. Empirical testing is the only way to validate.
As shown below (and in the updated posted workbook) maintaining the 0.001" chip-load requires an increase in feed rate from 50 to 138 IPM. That requires an increase in cutting force and power from less than 1.05 lbf and 27.9 Watts to 2.89 lbf and 76.9 Watts respectively and increases the MRR from 0.13 to 0.34 cu-in/min. Your(?) Makita router is likely capable of 0.52 X 746 = 388 Watts at ~30,000 RPM. So, it would be surprising if it couldnât easily provide 77 Watts at 18,000 RPM. Are you sure youâre not suffocating it by taping over itâs cooling fanâs outlet?
As a (not so?) retired, and likely somewhat(?) OCD engineer, I fully appreciate that âthere are plenty of system dynamics âthe numbersâ donât capture. Empirical testing is the only way to validate.â But, itâs the physics and math/numbers that dictate what needs to be validated/evaluated (at least it was before the era of Trump!).
Unfortunately I donât currently donât have my own CNC machine. So, Iâm relying on folks like @Julien, @Vince.Fab, @will, you?, and others? to provide feedback based on their experiences.
Winston is totally on the money about how cut direction on a stock shapeoko can be a major factor in speeds and feeds. In fact thatâs one of the main reasons from the beginning I migrated towards much higher rpm and later ridgidity modifications. Its why my dropped vise is mounted the way it is. Sometimes you can outrun the vibration but thatâs off topic.
If you have a shapeoko and you want to see where your weak links are just adaptive cut a heavy circle. I promise youâll hear two distinct areas of âdifferenceâ.
Iâm sure Winston pushed it as far as one should on a stock machine. I for one am very interested to see the changes to speeds and feeds using the new HDZ. Less wheels, less bad noises.
The workbook works well for me but maybe it needs input with bone stock machines to set realistic force limits. It tested fine to 60,000rpm at 400ipm and a conservative 0.5 cubes. Math looked good and it was easy enough to set it at a minimum chipload and fine tune off there based on force and power estimates
The workbook supports that, we just need to determine what those force limits are! Need numbers and maybe a translator (0.5 cubes?)
2019-09-10 Update: Since Winston already provided numbers in the videos posted here, I added sheets to the workbook for his additional Shapeoko aluminum and wood videos as well as his Nomad cast acrylic video.
2019-09-10 Moyâs YouTube Aluminum, Steel, Wood, and Arylic Video Speeds and Feeds Workbook.zip (373.9 KB)
His most aggressive cuts were in the âAluminum Machining Guide For the Shapeoko 3â
As shown below that likely required less than 1.7 lbf of cutting force and 40 Watts of cutting power and resulted in a MRR of 0.18 cu-in/minute. (Thatâs less than 1/10th the feed force and power capabilities of stock Shapeokos.)
As shown below, using that 1.7 lbf to set the feed rate for Vinceâs 60,000 RPM spindle resulted in a MRR of 0.68 cu-in/minute.
Since apparently no speed ratings are provided for the Carbide 3D endmills, they probably shouldnât be used at 60,000 RPM (or even above Winstonâs 18,000 RPM maximums?) So these endmills were used for those calculations instead.
Interesting that Winstonâs reply to one of the comments on the âSpeeds and Feeds for Wood on the Shapeokoâ video supports my assertion that, at least with wood, âmake dust not chipsâ.
" Winston Moy 2 months ago
Chipload isnât really a big deal, so I wouldnât worry too much about it. The reason it matters in other materials is heat. And here if you rub more than cut, youâll just see a little burnishing/blackening of the cut edges. That you can recover from because wood is forgiving, in aluminum youâd break a tool. If it works, just go with it. Woodworkers have been pushing router bits through wood by hand for decades, and i guarantee you they havenât measured their feedrates!" ![]()
Yes but I have seen many router bits that burned wood.
Cubes, you know, cubic inches per minute. Also I used a lakeshorecarbide 0.125 that is rated to 2000sfm. As far as the carbide 3d single flutes, they arenât perfectly balanced and I didnât like running them much past 26,000.
I dont understand you you wouldnât want to consider chipload on every cut. Do it at least for the tool life.
P.s. absolutely want to try 4000sfmđ
Thanks!,
The 5.5 lbf predicted cutting force would cause about 0.025" of machine deflection (measured at the tip of the endmill) each time an endmill flute entered the workpiece in our stock Shapeoko. It would be interesting to see if that is workable. Note that the 654 SFM (200 m/m) Vince used slightly exceeded the manufacturerâs recommended 550 SFM and was well below the âHSMâ cutting speed threshold.
I was trying to define a length of a ramp, not the type which is another good question. I think the ramp should be proportional to the size of the endmill diameter. A little guidance could be good since we recommend ramping.
It looks like he could have achieved about 3 times the MMR with a Kennametal endmill.
That endmill would also probably be a good choice for Titanium.
Well at least on paper. While I donât know much of either endmill, when choosing an endmill, the durability, the price and quality of the cut should also be factored-in. Maybe @Vince.Fab has tried both and can comment or maybe you found a pearl.
Anyone got a link that that calculatormajig? I tried to open one yesturday but it didnât work. Probably pushed the wrong buttons.
The fireplug is a 4 flute 0.325 loc and stickout was 0.625. Itâs awesome for what I need it for but wouldnât mind trying a 5 fluter one day.
Who wants to see a 6mm SF at 6mm adoc in ti?
2019-08-10 Vince Speeds and Feeds Workbook.zip (162.8 KB)
Itâs a Microsoft Excel workbook, which canât be uploaded. So I sent it to a compressed (zip) file for uploading. But you need Excel to use it.
