I am trying to carve a conical shape and I believe I have hit the limits of my software. I have tried Vcarve Pro and CC. I am doing some milling for a custom gunstock and I am stuck on milling out the fore grip where the barrel sits. As you can see the the bottom is a radius and tapers from 1 inch to .7 inches at the tip. I have not been successful in replicating this shape because I guess this falls into the 3d category. If anyone know how to accomplish this in either software I would love to know how.
Part two is I expect Meshcam will do it but not certain if it works with CM on the S3. Does it?
I have a 3D cad software that I could import to Meshcam.
Fusion360 I am sure will do it but don’t have time for the learning curve but it is option 3. Aspire is way too expensive.
@WillAdams Fantastick! I will give it a try! @Julien The only compatible format is a DXF file. It will import but I need to learn how to deal with it once I get it in. The preview was not what I expected so I think there is some learning to do here. But this is also looks like an option!
Thanks guys! you saved my Sunday afternoon from being a real drag!
@WillAdams downloaded CCpro and was able to to get 80% there. The one thing I can’t seem to do is control the z depth along to cone. Since the cone has a larger radius on one end and smaller on the other, the depth needs to get shallower as it get to the smaller end of the cone. From what I am doing I get a rounded bottom but the depth is constant along the length. This is what I have in my cad software. Sadly I can’t export as an STL.
@JeffWimer I actually thought about doing that as a last resort. Then it occurred to me that my daughter might be able to help. Graduating with a degree in Interior design in May! What a relief! I gave her the specs and she whipped out an STL file like a pro! About time I get something for all that money I spent!
Pulled into vcarve just fine. I do need to find another way to do this. It kinda hurts my man-pride ya know.
If anyone comes up with an alternative I’m all ears.
I wanted to post the final product here as an update for those interested. The barrel section is the 3D piece I was having trouble with. It came out quite nice! I did have to cut a section out of my baseboard and wasteboard and had to raise the machine to get enough depth to hold the grip portion which is 4 inches tall. Also had to buy a 3 inch long .25 endmill in order to cut 2 inches deep. This was a fun and educational project. My customer is very happy! Thanks everyone for your help!
