How can you hijack the thread when you started it?
“Let’s rush one more test before going to bed, 10 minutes should be plenty enough”
“Oh, and let’s forget to double-check that toolpath, and leave a lead-out at full depth, that will spice things up”
sigh…rust in piece, little Amana. You will be missed.
@nlichtenberg, great finished piece! I must admit I initially wondered what the deal was with all those jagged edges, but that retro 8-bit pixel look is fantastic!
EDIT: don’t forget the CutRocket bonus
I don’t get how the forum works when an existing post is edited, I don’t see it as a new post, so I missed your latest update before. Glad I went back and checked!
You can add more edge-lit LED light on the two corners where Mario is. Wouldn’t take much.
Thanks! And right, the cutrocket upload!
I think I also missed the edit made by @Sherpa even though I put a like on the post. Maybe the admins can change that notification behavior?
True, but then I would have to add LED in the first place. Currently all the light comes from the luminescent color in the epoxy: no need for a power source.
Well, how’s that working with Mario? Just sayin’. ![]()
I can see that the edges of the acrylic are lit by the epoxy. Maybe sanding the Mario area pretty rough will make him catch some light?
Probably I’ll just try, but that will introduce some intensive re-sanding if it doesn’t work.
Entry #1 (Henry’s Space Room)
The plastics contest hit at the perfect time for me as I was planning and working on several pieces that utilize the cutting of plastic. Long story short(er), we had our 3rd child at the end of March (crazy time to bring a baby into the world), and probably like many parents of two preschoolers, we didn’t prepare as much as we should have. Then quarantine happened and my wife decided that we would empty our “office” and move the 3yr old in there, so the baby could eventually move into the “baby room”. He got to choose what kind of room he wanted and he said “I want a Space Room”. My thoughts immediately went toward making a “control panel”, but that will be for another day (if I get the permission). My wife wanted a “less flashy” style for the room…she likes Pottery Barn and Crate and Barrel type stuff. Anyway, enough of it…here’s what I came up with.
There’s a few more stars and a “shooting star” on the opposing wall. The white is all 3mm white (very slightly translucent) cast acrylic.
All designed in inkscape initially, and then moved to Fusion for the toolpaths. The wood is just ¼” birch ply from Lowe’s also cut on the SO3 (the H-E-N-R-Y letters had been done a couple years ago). Acrylic super glued to the wood.
After some testing, I settled on:
⅛” single flute upcut endmill (cheap one)
Feedrate: 3210 mm/min
Speed: DeWalt on 1
Plunge: 888 mm/min
DOC: 1mm
Screenshot of initial Inkscape design:
I had to change the Earth design later because it didn’t fit the simple theme (looked like a PITA to cut). And the rocket? Well…more to come on that.
Anyone else measure success by whether or not you cut through the bottom layer of tape?
I really was surprised at how well the acrylic cut. I got to a “That’s a pretty good result” point almost right away, tried doubling the feed and got to a “That’s a faster way to get to a pretty good result” point. I didn’t need to do any post processing to the acrylic. I found that the key was to have it secured everywhere…I went through a LOT of tape and a LOT of Super glue. I’m assuming another key was that I was using cast acrylic. I had one break point that erased the Panama Canal, but it broke cleanly and now it’s part of my “simple design”.
Not knowing there would be a plastics contest, I just imported one SVG at a time into the same Fusion project. Basically used it as a template. I’ll share the Inkscape vector and the Fusion template (with toolpath). I just needed to change the sketch and update the toolpath. One could also use Carbide Create or any other CAM program.
HenryRocket.svg
SpaceRoom_Acrylic v2.zip (97.8 KB)
Entry #2 (Rocket Lamp)
I decided to submit this one separate because it definitely was a separate project. I wanted to make a light for the “Space Room”, and I wanted it to be the same theme with dark stained wood and white. Here we go.
Fusion Model:
Real Deal:
The acrylic (white and orange cast) was cut exactly as above:
Speed: DeWalt on 1
Plunge: 888 mm/min
DOC: 1mm
Frame was made from ¾” ply. Mitered corners with a dado groove to hold face
Face is ½” ply.
Back is ¼” ply.
Trim with mitered aluminum strips. (Sanded, but I thought HARD about trying some “engine turning”).
The back of the face was cut with a pocket for acrylic.
These were lightly glued and held in place with embarrassingly simple holders. The two holes in the white acrylic are for screws to hold the “windows” on the front of the rocket.
I added a barrel jack connector for power and routed that through a tiny led ring switch to another power connector to make adding the LEDs really easy. I wired the switch led to be always on.
After that, a bright white LED strip was wrapped around the inside.
Closed up the back with those little points to hold frame glass (the name is eluding me). Edit: glazing points.
Aluminum face frame was glued on with E6000 adhesive.
Fusion Design: RocketLight v4.zip (940.2 KB)
CutRocket Rocket: Rocket Lamp by neilferreri
@neilferreri: lucky kid(s)! For extra cool dad points, remake some of those stars in glow-in-the-dark material like @nlichtenberg did
Also, that rocket you cut should go on cutrocket.
My wife and I cut some stencils with her Cricut and she’s doing some glow in the dark painting on the dark wall. Of course that will somehow create a month of no sleep for any of us!
Will do… Still have another plastic entry coming. Like I told you, I’ve been cutting a lot of plastic recently. My 5yr old daughter couldn’t be left out…
My wifes parents stopped by over the weekend. They were on a 4000 mile motorcycle trip. My father in law just got a new GoPro so he could take videos on there trip. The first day he used it he lost the batter holder so i figured it would be fun to make one. I cut it out of delrin and it ended up working really well. I also added a nob so it was easier for him to located the camera button easier.
Fusion360 link: https://a360.co/3dXS4JO
CutRocket link: https://cutrocket.com/p/5efd372f3832f/
Battery_Holder.nc (58.2 KB)
At work i wear a mask all day and it hurts my ears. So i started using a 3d printed ear saver that hold my masks off my ears. This worked but i kept loosing it and braking them. So i decided to make one that attached to my bump cap that i have to wear. I have been using it for the past 2 weeks and i have not lost it and my ears do not hurt
Material: Polycarbonate 0.125 thick
fusion 360 link: https://a360.co/2NJl4tU
Cut Rocket link: https://cutrocket.com/p/5efd3d15ac4c6/
Delrin Bushings and Associated DIY Fixture Vises and DIY Lapping Tool
For this challenge, I would like to submit a seemingly simple project that I’ve been working on for the past 2 weeks: bushings made from 1.250" Delrin. I said seemingly simple because there were plenty of hurdles to overcome throughout this process.
Before I cover the problems I encountered, let me first explain what these bushings are for. I have a blower from an early 1900s metal forge which has worn out bushings.
I spent a great deal of time taking this whole assembly apart and realized the original bushings were made of steel. I wanted to make the new bushings out of something softer as to not wear out the shafts of this blower any worse than they already were. At first, I was going to use brass but I realized Delrin was it a lot cheaper, easier to machine, and is also used to make bushings. Let the fun begin😏
Problems
- How do I hold a piece of 2 foot long round stock vertically for machining?
- My limited selection of cutters is not long enough for 4 out of the 5 bushings I need to make. (longest bushing is 2.200")
- One end of the bushing must be machined in a secondary setup.
- Holding tight tolerances
To overcome the work holding problem, I created a wooden vise that overhangs the front of the Shapeoko. This vise utilizes a quick zeroing locator hole which corresponds with the machine’s front center rapid travel location. This allows me to slide a 1/4 inch dowel rod from its position in a loose collet and into the hole before tightening the 3 securing bolts. Then I run an indicator across the front of the vise (with the front jaw removed) to verify alignment along the x-axis. This indicator hole allows me to quickly resume work after switching zeros for other programs. Now with this vise, I can quickly hold the piece of Delrin at any height needed for my different length bushings.
To overcome my cutter selection problem I purchased a 1/4 inch 3 flute End Mill with an overall length of 4 inches. Before machining the longest bushing of 2.2 in I realized I was significantly close to maxing out the Z travel of my machine. I had already programmed my clearance height to 0.010 inches. However, the G53 code at the beginning of my program commanded the machine to make a Z movement -0.197 inches before moving to the x and y plunge point. If uncorrected this would cause a gouge across the top of my part within the first few seconds of the program. Additionally, the M02 command at the end of the program again caused the Z-axis to move (-0.197 inches I suspect) before traveling to the back of my machine. If uncorrected this would also cause a second gouge across the top of my part. A quick call tech support helped me understand the expected G-Code movements; thanks, Brandon. Next, I did a series of test runs away from my part as I removed the G53 line of code and the M02 line of code. After I was confident in the expected outcome I changed my zeros back to my part and proceeded to cut the bushing.
After operation one finished for each bushing I cut the bushing free of the material with a hacksaw. This brings me to the third major problem; how do I hold a small round object so that I may face the end? My vise only holds the larger round stock. I designed a simple V block vise which I could mount anywhere on the table.Note: a hose clamp can make a quick job of mounting a dial indicator
And now on to the fourth problem: holding tight tolerances. I started with running my spindle speed at 18000 and a feed rate of around 60 inches per minute. However, I quickly realized things were not rigid enough to hit tight tolerances and go that speed. The major drawback that I faced was cutter run-out. I’m sure the collet was partially to blame, but I noticed that I can wiggle the spindle nut on my Carbide 3D router forward and backward as well as side to side when tightened. This leads me to believe that the spindle bearing in my router is going bad (I’m not sure how tight this was when new). If anyone has any suggestions on fixing this please let me know. As for my project I wanted to continue so I slowed my feeds and speeds extremely.
Contour Operations for both ID and OD
Feed rate: 15 inches per minute
Step Down per Pass: 0.034 inches
Plunge rate: 4 inches per minute
RPM: 10,000.
I was still able to get chips from the Delrin and no melting. The surface finish was okay but not like you would see on the lathe.
I would like to fix the spindle bearing and try this project again to see what improvements can be expected in surface finish and how much faster I could push the feeds and speeds. To compensate for the run-out and spindle wobble I created oversized and undersized geometry for the OD and ID respectively. For each additional bushing (each one varies in size), I copied the previous program and saved it under a different file name so that I could make adjustments as needed without deleting or altering a proven program for the previous bushing (in case I ever need to remake these).The final problem I’ve had to overcome was the tolerance between each shaft and bushing. I created a makeshift lapping tool from a wooden dowel rod and a piece of a broken belt sander belt. This process slightly expanded the ID of each bushing until it would freely spend on the associated shaft.
And as @Griff would say: where’s the pic, or it didn’t happen (pretty sure I’m quoting the correct person, if not, my apologies). Here is the disassembled puzzle with old bushings, followed by the finished project’s installed Delrin bushings that were fully designed in Carbide Create and machined with my Shapeoko.
Most importantly, thank you to all those who post in these forums, as I have learned a lot from all of you!
Carbide Create CAD/CAM files: 0.880 OD Bushing Vise.c2d (49.6 KB) 1.287 OD Delrin Vise v2.c2d (2.3 MB) Middle shaft - hat bushing oversize.c2d (1.1 MB) Middle shaft - sleeve bushing oversize.c2d (2.2 MB) Outer shaft - sleeve bushing (started with oversize comp).c2d (2.6 MB) Upper shaft - hat bushing (2nd operation_hat OD).c2d (1.9 MB) Upper shaft - hat bushing (started with oversize comp).c2d (2.7 MB) Upper shaft - sleeve bushing (started with oversize comp).c2d (2.7 MB)
CutRocket Link: https://cutrocket.com/p/5efdedf60f0f4/
-James All
I finally got the material in that I was waiting for, so here is a new project. This is a riser/fixture for a vee block on one of my optical comparators. The finished product looks like this:
The stock is HDPE, as it is easy to machine, holds dimensions well, is moderately priced, and has a reasonable ‘feel’ for the application. Delrin is too pricey, but Oh so sexy. 4"nominal round bar (101.6mm, -0, +0.5mm is the spec) was used to minimize waste.
Lots of pics here, because I am that kind of nuts. The part was modeled in Inventor, but Fusion360 is real close.
For this kind of work, where the fit needs to be pretty close-- better than 0.1mm-- it is easiest to model what you fit to, then use offset parameters as needed for clearances. So, the aluminum well on the stage was modeled
and used as the basis to derive a solid for the riser
by using the well as a cutting tool
A flat was placed for the holding screw to seat to
and a seat cut for the vee block, with reliefs at the corners to keep crud from binding it up
and clearance was added for inserting into the plate by offsetting the OD at the bottom
And, as part of the setup for machining (this isn’t the base model— this is a working copy for doing the CAM) holes set for 3mm diameter dowel pins. This allows the two sided machining to be done with proper alignment.
You can see that many of the key features were defined as named parameters to make them easy to work with. There were only a few things where the named parameters were used to derive other features (the clearance grooves coming to mind)
Another simple model was made to machine a pocket to hold the base stock. It was used several times, as after the initial cut (intentionally too small) the size was offset to bring the pocket up to the correct size.
I think it took three iterations, as the base stock is a bit less round than I would have liked (out of spec, actually-- 101.6mm nominal, -0, +0.5. Actual was 103.7mm one way and a whopping 104.9 max.)
The stock was a snug press fit and no other holding was used.
These are the CAM operations for the main model.
The bottom first:
The boss to fit the well plate:
to get
Check the size
Then the lower portion of the OD
and dowel holes
The dowel holes were piolted with a small drill to provide clearance for the endmill to cylindrical bore. Technically not needed since the bore is less than about 1.8 times the endmill size and it will essentially be a helical entry, but the bore is so small relative to the endmill that the center may not clear properly, so a pilot reduced tool lossage and work lossage. The time for all of this is seconds.
And then chamfers
Do the dowels fit?
Yup.
Now machine fixture points for the second setup
The setup for this is the third setup in the main model. I copied the operations from the first setup for surfacing and the dowel holes, and made the origin match the origin for the second setup (the bottom center of the part)
put in dowel pins
and mount it
using a strip of 3M 467MP. The dowels are tight, but there isn’t sufficient surface area to prevent the part from lifting.
Machine the top (nothing to say here. Much the same, except for the relief grooves)
Final chamfer being put on
And test fit the vee block after a stiff toothbrush cleanup
As I had already run a test part, the side play is <0.05mm, which is what I wanted. The block is free to slide endwise, but has a little drag. The first test piece took two or three shots to get it sized right.
The model is attached. [riser-with-CAM-inventor.zip|attachment] should anyone want it. (upload://q2TYe0P4NEAyRR5jMWMxSTUMCj7.zip) (1.9 MB) The tools used were 3.18mm flat end, 3.18mm ball end, 1.59dia ball ens, 2.38 flat end for the dowel bores, and a 1mm dia drill for piloting for the bores.
The most time consuming part was the initial pocket fit for the rough stock. The supplier cut was cocked and rough, and my cut for the blank wasn’t any better using a handheld power hacksaw. I’ll shut up and top revising now. My shop manager just jumped in my lap (a 9YO black cat) and wants fusses.
Ok we now have acrylic/polycarbonate, HDPE, and Delrin covered.
Final day before the deadline!
Hi all,
As mentioned in another thread, I tried a wooden v-inlay in acrylic. Didn’t think I would finish today, but here’s my second entry:
Settings for the acrylic were like in my other project:
- 90° V bit at 1700mm/m and 17000 rpm
Then the male part of the inlay with plywood attached with wood glue, sawed and sanded off.
The acrylic was then sanded up to grit 3000 and I also put some linseed oil on. Not sure if that only cleaned the surface as @Sherpa mentioned or if it really hides some tiny scratches.
The base was cut from two sides to fit the LED strip and the acrylic sheet.
I cut out the base manually with a hand saw, so you see I really need those computer assisted machines
But parallel lines are boring, anyway.The files:
christian_plug.c2d (739.4 KB) LED_base.c2d (83.7 KB) christian.c2d (1.1 MB)
Whew - sliding in at the last moment. Did not start this project with the competition in mind, but the milling plastics competition has brought out some really interesting “make things work” entries so I figured I would throw mine in as well.
So I have an application for remote sensing and data collection in a marine environment. The intention is to capture forces, acceleration, and angles for human powered watercraft aka rowing shells, sprint canoes, surfskis, outrigger canoes.
Requirements are:
(1) needs to adapt to multiple environments (on hull, on oar, on paddle)
(2) needs to be waterproof! Somewhere around IP-68+
(3) needs to float - just in case
(4) needs to have a viewport to see LED status
(5) needs to be easily (but not too easily!) removable! for data download and recharge
(6) housing needs to pass bluetooth - no aluminum shell!
I had a Thunderboard Sense 2 development kit lying about to use for proof of concept so off to Fusion 360 we go for a housing to protect it.
a HDPE housing, a silicone gasket, a cast acrylic lid, and a UHMW mounting clip.
Designing the housing was quite straightforward other than some deep small holes for the M1.5 screws but designing a clip that would retain the housing that could release AND be machinable took a bit of pondering and fooling around. The clip will remain attached to the boat/oar/paddle and the housing would be removable. Eventually I settled on a slide-in style clip that would have a flexture to allow the retaining tabs to hold the housing in place. Machining could be done from the bottom of the clip to create the overhang and the flexture at the same time.
Once that was done it could be flipped and the inside of the clip could be pocketed out.
CAD done, off to machining. Again housing and lid pretty straight forward operations. I looked into machining the silicone gasket but it looked like I would have to freeze it with liquid nitrogen or some such equivalent so back to the craft knife and punches it was.
Machining the clip was the interesting bit (and also overlapped the competition) so I took photos.
Clip bottom complete
A little onion skin
Flipped, taped down, and edge finding the X and Y edges
Tabs looking OK!
Test fit before removal
It fits!
Mid clip-in
In mid-flex
And some preliminary testing of course
It floats!
Submersion test
Design files up on CutRocket! I hope someone finds the case/clip/flexture ideas useful!
Wow @PhilG So much to learn from this entry! Amazing work.
